👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...8 replies 177 views
Recently been having some trouble with my transmission, but specifically the torque converter I think. When driving home under light throttle, my trans will lock the converter around 45mph and begin to shutter and buck unless I speed up. Any ideas on what it could be? Slipping converter maybe?0 replies 3 views
I have a 1995, dodge 3500 12 valve I assume it has the 47 rh transmission I have posted pictures before of some sensors or wires that are not connected to the truck original I have replaced the turbo with the K 27 rebuilt the transmission and installed cages for boost EGT and transmission before...10 replies 137 views
Hey guys so I’m new to the 5.9’s, found one up for sale with 90k miles and had to have it. So I did all of the basic maintenance, air filter, oil change, transmission change. Well it’s now two days after the oil change and I decide to take the truck to work, when I got to work I noticed right...5 replies 152 views
