👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
1998 ram 2500 12 valve ac not working. Power at fuse 9 in cab junction box power at fuse J in engine bay junction box and power at relay pin 30. Metered continuity from Fuse 9 to pin 86, and metered continuity from PCM C1 to pin 85. No power at pin 86. Jumping relay pins 30 to pin 87 Will engage...10 replies 164 views
Good morning everyone! I have a 1998 12 valve with a 47RE transmission. I’m looking to do a G56 swap but have been struggling to find what I need to do with the wiring to bypass the neutral safety switch to start the tuck. If possible I would like to eliminate any check engine lights and would...2 replies 122 views
My truck was a factory Auto swapped to 5 speed trans. So I have found some auto trans remnants, but I don't know if this is one or what it is? Anyone know? 1 pic shows where hoses connect to the other shows the ends that were cut off.3 replies 141 views
Hey guys, this is my first post so hopefully I'm approaching this right. Today I took my (new to me) truck through an automatic car wash (probably my first mistake) and the check engine light turned on in the middle of it. I'm assuming the undercarriage wash hit something and caused all these...5 replies 119 views
My second gen had its transmission completely rebuilt according to the pervious owner. However it will not shift into 4th gear or go over 55mph (yes he told me this before I bought it). I have looked all over this forum and the only solution I have found is replacing the solenoids and relays. I...1 reply 30 views
