i have been doing a lot of reading on pump timing, i was just wondering if anyone has had any luck timing the pump with a normal magnetic base dial indicator??? i don't mind going and buying a kit but don't see the point if magnetic dial indicator will work, any opinions on this, sorry if it has been posted before did see it in any of my searches :confused013:
You do it just the same as here> TSB 18-10-94 Rev. A
except with a magnetic base you have to be very careful the base doesn't move.
Just a little movement will throw things off.
I use a mag base with a travel indjzicator to do mine.
