đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Been a while since I got the truck (see new member post from back in Oct) and had a chance to get on as it's been a crazy last few months. So far as you can see, I removed the decals, added Cruise Control (thank you YouTube) and installed a quadzilla XZT (mostly for the high idle but when...0 replies 0 views
Was driving my 2005 5.9 and clanking knocking noise started. Was onky a block from the house so pulled in driveway and also noticed coolant leaking near water pump. Replaced water pump and noise stopped but leaks fluid immediately when filling from behind AC compressor. Looks like the mount...17 replies 1K views
In the morning when it's cold or wet out the wiper intermittent positions don't work at first but eventually start working once the truck warms up. The module plastic near the connector shows signs of melting but I think the module is working properly and maybe the connector pins are not making...2 replies 137 views
