👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Thought I asked this, but maybe not here... Having a converter done tomorrow (local shop, cut, rebuild, upgrade). I have the option to go low stall (1600ish rpm) for added $. For a basically stock engine with a few free power mods, and the 727 (which is going to be redone also), does 1600 rpm...2 replies 84 views
This is the first problem with my 2012 RAM 3500. Today, while driving, I turned on the exhaust brakes, and I could feel that the exhaust brake was intermittent. Shortly after, the check engine light came on. I have code P226C reading Turbocharger boost control slow response. Now, when I turn...2 replies 82 views
Howdy folks it’s been a while since I’ve posted, I’m curious how much should a transmission rebuild cost in 2024, as well as having a transfer case resealed. I’m out west here in the pnw specifically Oregon.15 replies 254 views
I’ve done other bolt-ons with other hobbies on other forums but this will be my first time starting a build for something I don’t even own yet. 🙃 I hope to get feedback (positive and negative / I’m not sensitive - insults are welcome) because I will have a lot of questions. I’ve built a 2023...120 replies 9K views
