I know the Cummins 6BT engines are rated all the way from about 160 to 370 hp and assume the most of them have different fuel plates for the P7100 injector pump. If that is not true would someone let me know?
If it is true it would seem if someone that has access to the Cummins parts info might be able to put together a list of what part # is used with what CPL/horse power level for our engines. I understand the fuel plates from Cummins are much cheaper than after market plates and might be used for our build up purposes. I also understand other issues than the plate are involved, but this might help with cost on that item which is an issue for many of us.
Am I all wet here or on to something? I have searched and can't seem to find anything addressing the idea.
