đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
My second gen had its transmission completely rebuilt according to the pervious owner. However it will not shift into 4th gear or go over 55mph (yes he told me this before I bought it). I have looked all over this forum and the only solution I have found is replacing the solenoids and relays. I...1 reply 0 views
1998 ram 2500 12 valve ac not working. Power at fuse 9 in cab junction box power at fuse J in engine bay junction box and power at relay pin 30. Metered continuity from Fuse 9 to pin 86, and metered continuity from PCM C1 to pin 85. No power at pin 86. Jumping relay pins 30 to pin 87 Will engage...9 replies 161 views
Good morning everyone. Hoping somebody can give me some help on an issue. I installed the banks monster ram the other day and since installing on the center cluster I get a message with a red lightning bolt that says service electronic throttle control and I also get a p0254 “injection pump fuel...0 replies 0 views
I am getting a message exhaust filter full power reduced see dealer 5 days ago Feb 25, 1024 Message exhaust filter 80 full safely drive at highway speeds to remedy Then after driving another message exhaust system regeneration in process exhaust filter 80% full Then it dropped to 70%...10 replies 461 views
