đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
Thought I asked this, but maybe not here... Having a converter done tomorrow (local shop, cut, rebuild, upgrade). I have the option to go low stall (1600ish rpm) for added $. For a basically stock engine with a few free power mods, and the 727 (which is going to be redone also), does 1600 rpm...0 replies 3 views
Howdy folks, Can anyone get me started with a baseline rear caster setting on my truck? It's a 2018 2500 4X4 with a 4" lift. Looking at the position of the bolts, something is definitely off here. Rear passenger side of the truck sags an inch or two. With the steering wheel centered, the...9 replies 190 views
Hello to all. New account so bare with me . I have a 2003 Dodge Ram 2500 5.9l Cummins. I was wondering if i’d be able to pass smog straight piping the exhaust? I pass smog normally but want to go ahead and straight pipe. I know there’s no o2 sensors on the systems so there should be no problem...22 replies 401 views
1998 ram 2500 12 valve ac not working. Power at fuse 9 in cab junction box power at fuse J in engine bay junction box and power at relay pin 30. Metered continuity from Fuse 9 to pin 86, and metered continuity from PCM C1 to pin 85. No power at pin 86. Jumping relay pins 30 to pin 87 Will engage...8 replies 152 views
