just bought this truck monday. having a semi intermittant problem that is getting worse.
when it acts up the overdrive shuts off, the tach is inop, the alternator either doesnt charge or it pegs the voltage gauge, water in fuel and wait to start light stays on.
what ive done, i swapped the ESS with a known good one helped for a day, greased and tightened the connection on the ESS to upper harness, changed the alternator, and checked the connection at pcm.
no one can look at it till tuesday the closest pcm is 5 days out and i need to get to work monday please help.
im good at wiring can i put in an external regulator, and some how make it so i can put the truck in od manually? i live 40 miles from work so i need od
