97 12 valve * AUTOMATIC TRANNY NOT SHIFTING * HELP PLEASE! - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-03-2010, 07:08 PM Thread Starter
nostroker's Avatar
I just bought a 1997 Dodge Ram 2500 extended cab truk with 256-k miles. Was unable to drive it and now I find out the transmission does not shift at all.
It acts like it is starting out in 2nd gear. Tried to shift it myself and even push the od buttonon and off with no luck. I did notice that the tack is not working and the abs and brake light are both on.
Any ideas?
Just a farm truck, with some extras!
2007.5 Dodge Ram 3500 C/C 6.7L, auto, 9'.4" CM HAULER BED, front replacement, H&S XRT with deletes and S&B INTAKE!
nostroker is offline
post #2 of 7 (permalink) Old 12-03-2010, 07:18 PM
Maybe a solenoid in the transmission is bad. Your best luck will probably be to get it checked by a reputable transmission mechanic.
1964 Dodge W200 Power Wagon, Crew Cab, Manual
2002 Dodge Dakota SLT, Regular Cab, 4x4, V6 Magnum, Auto, Flowmaster dual exhaust
BigRig_88 is offline
post #3 of 7 (permalink) Old 12-03-2010, 08:35 PM
Try to find someone with an OBD II scanner with live data and let them check it while running. This will allow you to see what the PCM sees in all it's inputs. Problems you are having could be just as simple as an ESS (engine speed sensor) bad or more complicated as bad wiring and many, many other things, but first step I think is to see what PCM sees to start diagnosing. You need to properly diagnose before buying any parts.
RPegram is offline
post #4 of 7 (permalink) Old 12-06-2010, 12:45 PM Thread Starter
nostroker's Avatar
Well we put a Snap-On scanner on it today and it show governor pressure sensor and rear abs sensor. We cleared the codes and was able to shift it manually then when we stoped the codes came back on.
I found a new pressure sensor for $48.00 and abs senor for $46.00. Guess we will try this and see what happens now.
post #5 of 7 (permalink) Old 12-08-2010, 12:56 AM
espn1044's Avatar
just be sure to replace the pressure sensor and gov pressure solinoid at the same time, i didnt do this the first time mine was acting up and i had to do it twice, i think u can get them as a get for $110
just a lil 6 cylinder haha
espn1044 is offline
post #6 of 7 (permalink) Old 12-08-2010, 01:02 PM Thread Starter
nostroker's Avatar
Thanks, Just did that yesterday. My mech called and told me that I should replace both at the same time. Cost $48 for on and $41 for the other from a local tranny supply house down the street from me.
Hope to have it going today.
post #7 of 7 (permalink) Old 12-13-2010, 01:41 AM Thread Starter
nostroker's Avatar
No shift problem fixed!
Well after replacing both gov pressure parts in the tranny we ended up fixing the problem with a $120 engine speed sensor (cps). Someone had taken it completely off of the engine. But still can not figure ot why we was not getting any codes for that.
Any way the truck is fixed and shifts perfect now.
