uh oh. please help! - Dodge Cummins Diesel Forum
Old 12-03-2010, 05:22 PM   #1 (permalink)
uh oh. please help!
got a 1994. if u pull the dipstick out of the tube while the truck is idling the blow by is so bad it shoots oil out of the tube onto the motor. any ideas?
coal_roller_94 is offline   Reply With Quote
Old 12-03-2010, 05:24 PM   #2 (permalink)
gary502's Avatar
i got the same problem, just leave the oil fill cap off or add a valve cover breather....
95 2500 4x4 5 speed, reg cab, 12 valve, 90hp injectors, fuel plate DELETE, 5'' stacks, 35" nitto terra grapplers, valair single disk (looking for a double).
gary502 is offline   Reply With Quote
Old 12-03-2010, 05:26 PM   #3 (permalink)
twin64's Avatar
How many miles does the truck have on it? What all is done to it? Does it have a pulse to the blowby? Could be bad rings, hole in a piston, or vacuum line leak somewhere causing excess crancase pressure.
02 ecsb duramax with a zf-6.
"Give careful thought to the paths of your feet and be steadfast in all your ways." Proverbs 4:26
twin64 is offline   Reply With Quote
Old 12-03-2010, 05:27 PM   #4 (permalink)
but is something wrong. like blown rings?
Old 12-03-2010, 05:29 PM   #5 (permalink)
Obviously there is an issue somewhere, the answers to the above questions will tell you how bad it is.
05 3500 Quad shorty. 4 1/2" Fabtech, Smarty, 4" pipe, pillar gauges, h0tr0d custom front and rear bumper, 35" Cepek FCII's on black Rockstars.
h0tr0d18 is offline   Reply With Quote
Old 12-03-2010, 05:30 PM   #6 (permalink)
230 thousand miles. had 2 blown head gaskets. now its got arp head studs. 20 over marine gasket. 60 lb valve springs. 4k gsk. no plate. afc mods. huge exhaust. BHAF. mack rack plug
Old 12-03-2010, 07:55 PM   #7 (permalink)
God prefers Diesels's Avatar
If you're going to hang around awhile, why don't you put all that in your sig? I'd plug the vacuum pump and see if it quits.
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Timing in 40 minutes (P7100)
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline   Reply With Quote
Old 12-03-2010, 08:28 PM   #8 (permalink)
do u mean rebuild the vacumn pump?
Old 12-03-2010, 09:07 PM   #9 (permalink)
see if your blow-by tube hangin off the left hand side of the engine behind the pump is clogged
Bobby
crabbelle is offline   Reply With Quote
