Broken Headstud!!!!! - Dodge Cummins Diesel Forum
Old 12-01-2010, 01:26 PM   #1 (permalink)
Nickscott89's Avatar
iTrader Score: 7 reviews
So my buddy was retorquing my headstuds for the first of three and onre broke of in th block, we arent sure if its above the block or even with the block, trying to get ideas of ways to get it out if it is even with the block. We are possibly going to drive it that way and see what happens and if its ok I will leave it that way for now.
2002 6 speed HO, Edge Juice, Raptor 150,200hp JL Machine injectors,AFE Intake, FB 5" straight pipe, SB DD 3250, and other goodies!!!!!
2000 3500 5 speed, airdog,blue chip vp,s300,sbdd,edge cs,dual 4" exhaust etc
Nickscott89 is offline   Reply With Quote
Old 12-01-2010, 01:33 PM   #2 (permalink)
estrada5.9's Avatar
What was your buddy torquing them to?
Did he lube the nuts again?
Ez out if it is even with block.
2003 QCSB
estrada5.9 is offline   Reply With Quote
Old 12-01-2010, 01:43 PM   #3 (permalink)
ykdave's Avatar
i would advise against running it like that, you can end up warping the head
Pull it apart and dig out the stud. Luckily their may not be any pressure on the stud and you can spin it out by hand or even with a magnet if it broke down inside the block. if not, your in for a bit of work...
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 12-01-2010, 01:59 PM   #4 (permalink)
Torquing them to 120 and used plenty of the lube.
Old 12-01-2010, 02:09 PM   #5 (permalink)
renopker's Avatar
If you can get at it try a left hand drill.Use a small bit using a tube as a bushing then use the left hand drill it should grab and come out if its not bottomed out.Score another for the broken head studs
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand
renopker is online now   Reply With Quote
Old 12-01-2010, 02:35 PM   #6 (permalink)
If you have access to a tig welder you can build up the end of the stud and put a vise grip on it and back it out. I do it on inline 6 jeeps alllllllllllllll the time.
Wanting A Dodge....Driving a Ford.
aekrogh is offline   Reply With Quote
Old 12-01-2010, 03:11 PM   #7 (permalink)
OrangeP's Avatar
measure the broken stud up against another stud of the same length and see how deep its broke. that will give you an idea of where it is broke at
98 12v hand shaker, Mumau diesel, Keystone diesel
Running Mayville WI's best injectors
OrangeP is offline   Reply With Quote
Old 12-01-2010, 03:18 PM   #8 (permalink)
schueller74's Avatar
I agree with orange p.....And if you can get it out without an ez out you should be in good shape.
worst case scenario you will have to get a new hg and start over
96 2500cclb 4x4 NV4500 Lots of goodies
schueller74 is offline   Reply With Quote
Old 12-01-2010, 03:26 PM   #9 (permalink)
This happened to me on a 4.6 cobra engine, stud was 3" in the block. Used a drill bit one size under hole to get a center point. Get an EZ out and continue to drill hole to recommended size, tap in ez out and out will come the broken stud.
Yzracer931 is offline   Reply With Quote
Old 12-01-2010, 07:58 PM   #10 (permalink)
I hope its sticking above the head and this is something easy.
Old 12-20-2010, 06:35 PM   #11 (permalink)
Well we got the head off yesterday and the second to the last one broke off which is the one that has a dowel and from what I understand that dowel can be removed and he thinks he can get pliers or something in there and turn it out, is that correct?
Old 12-20-2010, 10:01 PM   #12 (permalink)
I would soak it with Kroil before you try to pull it out. KanoLabs.com That stuff is amazing - accept no substitute.
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust
Bought 4/28/07
bob95065 is offline   Reply With Quote
