Oil Leak suggestions? - Dodge Cummins Diesel Forum
Old 11-28-2010, 08:46 PM   #1 (permalink)
plv
It appears that my oil leak originates higher up on the engine than at the oil pan level. I have noticed oil dripping on the right tie rod. Any ideas on what the origin of this leak might be? I purchased this well-loved on truck from someone who did all their own work, and it has been a dream. I am a newbie to this forum and I don't do my own mechanical work. I can get to a cummins diesel mechanic in about 2 hours, but don't want to be taken to the cleaners due to my red hair and gender. Any advice would be greatly appreciated.
plv is offline   Reply With Quote
Old 11-28-2010, 08:49 PM   #2 (permalink)
zthatzmanz28's Avatar
Timing cover? KDP? Loose / leaking oil filter? I would start with doing the KDP if it hasn't been done yet. Cummins mechanics are expensive. Find a friend and have them show you how to do some work. WHile the 12v is cheap to work on, that only applies when you do the work yourself, not a shop.
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Larry B Solenoid & relay rebult 47re low stall TC
zthatzmanz28 is offline   Reply With Quote
Old 11-29-2010, 10:03 PM   #3 (permalink)
plv
Re: my oil leak
Thank you for your suggestion. I know the front end from the back. How to check under the hood to see if I have oil, and to always choose fuel with a green handle. If it had a psychiatric disorder I would be able to work on it. Oil leak is another thing. I will try to find a local mechanic. I appreciate your getting back with me. plv
Old 11-29-2010, 10:19 PM   #4 (permalink)
rkadcock's Avatar
Check the valve cover gaskets as well... They're pretty tough gaskets but they do sometimes leak. I had my #5 and 6 covers leak because the cover didn't seat in the gasket completely and it made a mess all over my passenger side of the engine.
97 Brilliant Blue 2500 Sport 608/1282 - Before the Build
Built & Balanced Motor, 5x.018, 550cc Pump, P&P Head, 188/220, Suncoast Trans, & 351/GT5591 Compounds
rkadcock is offline   Reply With Quote
