Can I drive without rear driveshaft? - Dodge Cummins Diesel Forum
Old 11-22-2010, 10:37 PM   #1 (permalink)
genestealer's Avatar
It started snowing in here, but I can't use 4WD because truck has different gears in front and rear axles. I was wondering if it's OK to disconnect rear drive shaft and drive only with front one? Would it break anything if I do it?
96 3500 CCLB, 4x4, auto
genestealer is offline   Reply With Quote
Old 11-22-2010, 10:40 PM   #2 (permalink)
Big Deezul's Avatar
i think you would be fine.
97 club cab 4x4
Big Deezul is offline   Reply With Quote
Old 11-22-2010, 10:50 PM   #3 (permalink)
it wont hurt anything but if you dont have a bolt on style rear yoke, your fluid will run out
joes_yj is offline   Reply With Quote
Old 11-25-2010, 12:57 PM   #4 (permalink)
dylon_333's Avatar
what gear ratio are you running im in the same spot. i have 4.10s in front and 3.54s in rear looking for a set of 3.54s for front?
GOING FOR BROKE!!97 4x4 ext cab 5 speed! bored .020 over, dfi 5x.014 injectors super 40 turbo 4-5 in exhaust southbend D.D clutch/hydraulics 315/75/16 toyo open country mud terrains on M/T classics pwr lok & 3.54 gears
dylon_333 is offline   Reply With Quote
Old 11-25-2010, 04:53 PM   #5 (permalink)
yes you can do. its happen to me before. i snapped my rear drive shaft and drove front wheel drive for 15 miles and no problem at all. but you got to be soft with pedal use wisely.
04 CTD 5.9 4x4, 6" tough rough,3" PA bodylift, fox 2.0 all 4 corner, 20" rockstar, 37" Nitto extreme mud grappler,Steering box brace, MP-8 Tuner,Diablo Trinity T1000, S&B air intake and Horn intake,Train Horn (total 7 horns), DDm 55w HID kit
D3afCummins is offline   Reply With Quote
Old 11-25-2010, 04:55 PM   #6 (permalink)
Same here, 4.10 front and 3.54 rear, need 3.54 in front.
Old 11-25-2010, 07:26 PM   #7 (permalink)
ykdave's Avatar
you can do it, but you had better be granny driving it!
The front driveline is not intended to see full power transfer, if you get a little happy on the pedal you are liable to start braking things (most likely front driveshaft)
High speeds are also hard on the front driveline
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
