Have you tried changing valve cover gaskets? When they go bad they can leak a lot of oil. Since you have a diesel, you can plug every hole in the engine crankcase and she still won't chug. You don't have a PCV valve pulling vacuum on crankcase since the intake of your diesel has no vacuum. Vacuum is created 100% by vacuum pump which dumps into the crankcase so it would do no good to attach a PCV to that. By plugging all the holes all you will accomplish is a lot of blown seals and gaskets.
