355 vs 410 gears - Dodge Cummins Diesel Forum
Old 09-20-2010, 09:32 PM   #1 (permalink)
355 vs 410 gears
I mainly use my truck for sled pulling and a hot rod. I recently broke my rear pinion on my 355 gear and im thinking about changing to 410. I pull in 4low and right now second gear is to low and third is to high? any thoughts or experience in how this will hurt or help me.
1995 sledpuller 0 plate, LC dv, fass fuel, 370 injectors, afe intake, Silver Bullet, 5in stack, suncoast trans
95cummins06 is offline   Reply With Quote
Old 09-21-2010, 12:16 AM   #2 (permalink)
VP Moderator
dozer12216's Avatar
HJave to change both gears as sure you aware. gear would change your issue.
2008 3500 stock QCLB dually Inferno red. Toys of all sizes:Fuel injected Rampage, Grader, 1586 tractor, 60K genset, Honda Foreman ATV, and more. Back in business with a Hitachi EX270LC excavator. The dirt slinging has begun with 50+ acres to clear.
dozer12216 is offline   Reply With Quote
Old 09-21-2010, 02:22 AM   #3 (permalink)
Ridemywideglide's Avatar
What about the carrier? I was told you have to change the carrier for that swap. Makes it pretty expensive.
1996 2500 CTD, Ext Cab SLT, Longbed 4x4, 260K, 5 spd, 4:10's, 4 inch lift, 315/75/16's, Max Spool 2, HTT 64/65/12, Smokem's 5x012's, No plate, Hacked AFC, Autolite EGT, Boost & Fuel Pressure guages. 2005 Wideglide, 98ci, 37g's, 10:1, race heads.
Ridemywideglide is offline   Reply With Quote
Old 09-21-2010, 05:49 PM   #4 (permalink)
I thought the carrier was the same and you could just change the ring and pinion. front and back
Old 09-21-2010, 06:03 PM   #5 (permalink)
I want to marry my truck
madmikeismad's Avatar
I'm 99% sure you don't have to change carriers.
Purple People Eater - Low and poorly tuned. http://picasaweb.google.com/mch8223/Diesel#
The Race Truck - New drag truck with big plans!
https://www.youtube.com/user/THEmadmikeismad/videos
madmikeismad is offline   Reply With Quote
Old 09-21-2010, 06:08 PM   #6 (permalink)
thanks thats what i thought any idea how much lower in speed the 410 would be in 4low 3rd than the 355
