Front hub trouble... - Dodge Cummins Diesel Forum
Old 09-19-2010, 10:58 PM   #1 (permalink)
Dallasfire911's Avatar
Ok so after getting a leveling kit installed i noticed something.. Making left hand turns were not a problem, nice and sharp.. right hand, not so much. i almost hit a car because it need so much room to make a turn. went camping, went in to town sounded like something was off balance, thats when i noticed that the whole front end minus the drivers side was still engaged, ended up dropping the front drive line in the parking lot... any ideas?
97' 3/4 ton custom exhaust, gauges, 36psi 35x,#0 plate, MANUAL fuel shut off, BHAF, 47re converted to a nv4500 w/ 450hp south bend clutch...
Dallasfire911 is offline   Reply With Quote
Old 09-20-2010, 12:37 AM   #2 (permalink)
come on someone has to know something that would help
Old 09-20-2010, 12:40 AM   #3 (permalink)
ykdave's Avatar
Whats the issue?
The outer shafts always spin, the hubs do not 'unlock' like most typical 4wd front ends. Dodges use a central axle disconnect (CAD) which disengages the passenger side inner shaft from the outer shaft, which keeps the carrier from spinning the driveshaft when your in 2wd.
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 09-20-2010, 12:42 AM   #4 (permalink)
ah well somethin isnt disconnecting then, i had to pull the drive line because it was making so much racket
Old 09-20-2010, 10:29 AM   #5 (permalink)
ykdave's Avatar
the CAD's tend to be troublesome units
Diagnosing 4WD Engagement Problems on Dodge Ram pickups
Also, if its making a racket, its time to rebuild the front driveshaft. Typically the centering ball in the double cardan joint wears out and causes all kinds of vibration and noise
Old 09-20-2010, 02:13 PM   #6 (permalink)
Banned
^^^^^ CAD setup = a joke
hence why i have gathered parts to do this : Dodge Ram 2500 4x4 Dana 60 Hub removal and converison to Ford Knuckles - Pirate4x4.Com Bulletin Board
Free Spin Hub Question - Competition Diesel.Com - Bringing The BEST Together
Kronic_187 is offline   Reply With Quote
