overflow valve and governor springs - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-17-2010, 09:58 PM Thread Starter
what kind of syptoms do these have when they go bad or a governor breaks.. my truck is still popping and cracking and burning raw diesel fuel at 2200 rpm and beyond ONLY at WOT i can have it half throttle and it runs fine..i can also just drive it easy and it runs just fine..what i have done so far is advanced timing incase it slipped, that did not help,lift pump and took out fuel heater..any ideas would be nice i am needin my truck to work it
94 2500 green RCLB 5 spd. 20 inch wheels,nitto trail grapplers,hybrid turbo,0 plate,BHAF,pump fully tuned,18.5*timing, mack plug,full cut DV's,ARP's,o-ringed head,188/220 hamilton cam and push rods, 5x.014 injectors pop pressure increased,DD ceramic valair & input
smken u is offline
post #2 of 8 (permalink) Old 09-17-2010, 10:01 PM Thread Starter
and if it is the overflow valve where can i get a racing app one that is wht my buddy who works at a performance shop is telling me it could possibly be and to try next but i want more opnions cause i am tight on money
smken u is offline
post #3 of 8 (permalink) Old 09-17-2010, 10:05 PM
CO President
ninerqb8's Avatar
Just s stock OFV would work fine you can get them from pure diesel power. If you want something more you can look at the Tork Tek adjustable one.
Overflow valve kit 94-98 12 Valve Cummins
TORK TEK CUMMINS ADJUSTABLE OVERFLOW VALVE OFV030 - Tork Teknology
98 12 valve. 2014 EcoDiesel
Owner BH Diesel Service
ninerqb8 is offline
post #4 of 8 (permalink) Old 09-18-2010, 07:10 AM
Have you done any type of diagnosing, like fuel pressure? If timing is correct and fuel pressure is where it needs to be, then that doesn't leave much. First of all you gotta know what the fuel pressure is. You should have checked fuel pressure prior to lift pump. That could have saved you some dollars.
RPegram is offline
post #5 of 8 (permalink) Old 09-18-2010, 09:04 PM
zthatzmanz28's Avatar
We just installed the Tork Tek overflow. It corrected the idle and we can feel it is more stable on acceleration.
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Posi-Loc Larry B Solenoid & relay rebuilt 47re low stall TC
zthatzmanz28 is offline
post #6 of 8 (permalink) Old 09-19-2010, 04:03 AM
I have the Tork valve, it's good stuff, but it's also cheaper than the one listed on Pure Diesel's website. There used to be a good link for a $36 or $39 (can't remember) one on eBay that was a direct replacement, so I'd say either go with that one or spend $10 more for the upgraded Tork
Keep in mind, depending on if you run Veggie Oil or have an aftermarket fuel pump, you may need a different part number, check the Tork website for details...
97 12v 5sp 4x4: 5x.012 FBD Injectors, 60mm Upgraded HX35 from HTT, 19* Timing, 4K GSK, ARP Head Studs, BHAF, 4" Exhaust, Random other go-fast stuff...
Also: 01 Ram v8, 94 GMC 6.5L Diesel, 02 Jeep TJ v8, 82 Trans Am v8... and no free time
Phantom1016 is offline
post #7 of 8 (permalink) Old 09-19-2010, 05:12 AM
torqmonster's Avatar
If it were governor springs you would have revving issues, high idle, not idling down - free revving, so you could probably rule that out.
Pabst Powered Twelve Valver
torqmonster is offline
post #8 of 8 (permalink) Old 09-19-2010, 06:03 AM
ykdave's Avatar
x2, you definitely know when its a gov issue. the gov is basically what makes the engine run. if it is malfunctioning in anyway, the engine is either not going to run at all, or the engine is going to run away and spill its guts on your driveway.
Your symptoms sound 99% like a fuel supply problem (low pressure, or air in the lines)
ykdave is offline
