Dana 80 hub removal - Dodge Cummins Diesel Forum
post #1 of 54 (permalink) Old 08-11-2010, 01:01 AM Thread Starter
Dana 80 hub removal
I was upgrading my rear wheel cylinders to the bigger chevy 3500 cylinders today and noticed that there was a rather severe oil leak coming from the passenger side axle/hub. I pulled the drum off and everything was coated in 80w90. I decided to try and replace the oil/axle seal so I could have a functional brake again but when I removed the axle I saw that the hub retaining nut is a ~2-5/8" nut...where can I get a socket to remove this nut? I went out and bought a socket from tractor supply but it would not fit in the opening.
Also, any exploded diagrams or other information would be appreciated.
1998 QCLB 12v 2500 4x4 5spd
Scotty II intake, 304 stainless 4" TBE, #10 plate FF, Isspro boost & EGT guages, 43psi
Rowingfish87 is offline
post #2 of 54 (permalink) Old 08-11-2010, 01:42 AM
sdiesel's Avatar
quite simple
napa or any other shop sells these sockets and you should have one in your tool box with the application of the socket marked in junk yard pen on the side so you remember which truck it fits
kd tools sells them otc tools sells them and many others do too.
its a must have
now is a fine tome to replace both seals and to clean the hub out and then convert to synthetic gear oil in the rear axle.
1994 3500 dually build date:12-93 new:trans, t case, cage long arm suspension sulastics, pre filter/heater MIA / HX35/40 4/5inch exh more much more
sdiesel is offline
post #3 of 54 (permalink) Old 08-11-2010, 12:47 PM
Some shops even rent them. As written above, best to buy one.
96 reg cab, 5sp long bed 4x4: 4GSK, pump and AFC altered, AFE filter, gasket matched and ported exhaust manifold, Fluidamper, 4" exhaust, gauges, 5th gear upgrade, KDP KO'ed, Hamilton cam, Southbend Con OFE, Bosch injectors, Dynatrac axles and hubs (don't go there, they don't stand by their product), airplane landing lights, Dana Powerlok's front & rear, front truss, F&R skid plates, runs on WVO.
Baja is offline
post #4 of 54 (permalink) Old 08-11-2010, 01:35 PM
Banned
it's a 2 an 9/16" axle hub nut socket....
any specialty tool store will have it
Kronic_187 is offline
post #5 of 54 (permalink) Old 08-11-2010, 01:51 PM
ykdave's Avatar
some automotive stores (such as napa, where i got mine) sell the thinwall sockets
ykdave is offline
post #6 of 54 (permalink) Old 08-11-2010, 03:54 PM
whoabeats's Avatar
Sometimes I hate how much information can vary on these sites, and I dont think its anyones fault but I did this job last week and it requires a 2-1/2" socket that i got from napa. My jumbo socket set wouldnt fit in the hub so I had to buy the special one.
97 2500 4x4 5spd, 4kgsk w/ 60#ers, 33" Retread BFG AT's
, BD super B special, valair dd, studed & o'ringed, 98-99 HD steering swap
whoabeats is offline
post #7 of 54 (permalink) Old 08-11-2010, 05:02 PM
ykdave's Avatar
yea, i thought that 2 9/16 sounded big... but i didnt have my socket handy to check!
ykdave is offline
post #8 of 54 (permalink) Old 08-11-2010, 09:56 PM
whoabeats's Avatar
Yeah haha I went out to the garage to look at it and just make sure I was absolutely correct haha
post #9 of 54 (permalink) Old 08-12-2010, 01:48 AM
macd's Avatar
My christmas gift to all of you theres a service manual for you.
98.5 2500, auto, 4x4, 4in turbo back, afe intake, adrenaline, Raptor 150, 1/2" lines,4 in. Kore lift, 37/12.5/16.5 Wrangler military MTs, tonneau cover, bigger sticks, Big head wastegate actuator, turn over ball and rapid hitch.
macd is offline
post #10 of 54 (permalink) Old 08-12-2010, 02:40 AM Thread Starter
My fsm was the first place I looked for the socket size and all it had was the dodge service part number...aka useless to us diy-ers.
thanks for the quick responses. I'll be running over to napa tomorrow to see if I can get one.
post #11 of 54 (permalink) Old 08-12-2010, 11:34 AM Thread Starter
now...can anyone give me the part numbers for the seals I'll be replacing? I want to replace the seal between the axle tube/housing and the hub as well as the seal between the axle shaft flange and the hub. I looked on several auto part stores websites and couldn't really find anything...
post #12 of 54 (permalink) Old 08-12-2010, 01:50 PM
whoabeats's Avatar
I used napa part # 28754. This product is an improved product over stock. It has a better seal design and if installed correctly should last the life of the truck. btw that part number is for 3/4 ton's. If you have a dually you need the one for 3.5" brakes not 2.5".
