No power steering or brakes - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 07-30-2010, 09:04 AM Thread Starter
goosekllr's Avatar
So yesterday i was heading to work and all of a sudden i had no power steering and my brakes went out to. It is all you can do to push the brake pedal in an inch. This problem happened all of a sudden there was no weird noises it went from driving great to this. My brake and power steering fluid levels are all good to. My truck has a 12 valve swap so i wasn't really sure if i should post this here or in the 2nd gen 24v section so if it's in the wrong section mods please move it. Thanks!
2001 Dodge 2500 4x4 w/12v
HE351 over S475, DDP Comps, Benched 181 Pump, 197 Dv's, Suncoast, FASS, Tork OFV
TNT Performance
goosekllr is offline
post #2 of 15 (permalink) Old 07-30-2010, 09:27 AM
youngcummins08's Avatar
do you have a hydroboost setup or did you swap in a vacuum setup
my rig
96 2wd reg cab 2500, 405k miles, sport conversion, K&N. Replacment airfilter, homemade 4in.
youngcummins08 is offline
post #3 of 15 (permalink) Old 07-30-2010, 10:04 AM Thread Starter
goosekllr's Avatar
It has a hydroboost setup i am a powerstroke guy and this is my first cummins so i just wanted to make sure that's what it was. Is that the only thing that could be wrong? Thanks.
TNT Performance
post #4 of 15 (permalink) Old 07-30-2010, 11:51 AM
Mine has done the same thing twice and both times it has been the power steering pump. Chances that is the same thing that is happening to you. I would replace the pump first then look at the hydroboost. jmo
2012 2500 Magacab, Bilstien 5100's, Amp Energy steps, CCV Mod, 3" lift front springs, S&B Cold air intake.....
turboAl is offline
post #5 of 15 (permalink) Old 07-30-2010, 11:53 AM Thread Starter
goosekllr's Avatar
Cool, might be a dumb question but why would the brakes go out if the power steering pump went up?
TNT Performance
post #6 of 15 (permalink) Old 07-30-2010, 12:00 PM Thread Starter
goosekllr's Avatar
I just remembered the guy i bought the truck from just put a power steering pump on so hopefully it isn't that.
TNT Performance
post #7 of 15 (permalink) Old 07-30-2010, 03:28 PM
dwr91's Avatar
Your breaks would go with your powersteering on a hydroboost setup because your power brakes work off of your powersteering, unlike a gas job that works off of vacum from the engine, some of the 12v have a vacum setup i believe from 96 on back through the older ones.
1996 3500 eclbd, 5sp, #10 plate full forward, all afc mods, Autometer phantom gauges,
Oh yeah and a brand new valair clutch not installed yet
aka Sh1ty ol 12 valve
dwr91 is offline
post #8 of 15 (permalink) Old 07-30-2010, 03:33 PM
your power steering pump, not only pressurizes your steering to amke it easy to turn, but it also pressurizes your brakes to make it easy to push your brakes.
towingtime is offline
post #9 of 15 (permalink) Old 07-30-2010, 08:49 PM
Yeah, what he said.............................................. ...
turboAl is offline
post #10 of 15 (permalink) Old 07-30-2010, 08:52 PM
ykdave's Avatar
ill take another vote for pump failure. no pump + hydroboost = no power brakes or steering (fun!)
Pull the pump off and check the coupler between the vac pump and PS pump, it is also another common failure point in this situation
ykdave is offline
post #11 of 15 (permalink) Old 08-02-2010, 07:10 AM Thread Starter
goosekllr's Avatar
Tell me about it i ran some dude off the road when i exited off the highway it wasn't cool at all. Thanks for all your help!
TNT Performance
post #12 of 15 (permalink) Old 08-02-2010, 08:55 AM
blackimpala's Avatar
Before you buy a new pump try this: powersteering
It worked for a friend of mine and others on the forums. He did not enlarge the orifice just cleaned the screen and striched the spring.
Floyd
blackimpala is offline
