how to adjust idle on 97 5.9 - Dodge Cummins Diesel Forum
Old 07-15-2010, 08:39 AM   #1 (permalink)
Just bought a 97 yesterday. It's got a dr.'s performance injector pump and injectors on it. I believe this is a factory pump that has been upgraded. It has a lot of power and runs fine, but the heavy duty torque converter pulls the idle down too far when backing up or going forward at an idle. If you try to steer and back up it will die every time. Just the pull of the power steering pump is enough to pull it down far enough to die. I think speeding the idle up 100 rpm would help. How do I do it?
I can't see anything on the throttle arm.
I called my buddy who sold it to me, he said he just got used to using a little pedal pressure when idling around. I think this is a pain in the butt. I'd rather not have to hassle with it. I know the other option is putting the stock torque coverter in it, but I'd rather not, if I could raise the idle.
choward is offline   Reply With Quote
Old 07-15-2010, 08:45 AM   #2 (permalink)
Got P7100?
mathews8pt's Avatar
iTrader Score: 7 reviews
Look towards the back of the pump where the throttle linkage goes. With the truck off move the linkage to full throttle and you can see the bolt that it sets on at idle. turn it counterclockwise about a full turn.
Its right back behind this part of the linkage
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s468, tranny built by me, AD150, 11.60@117mph
1999 QCLB comp box and a trans by me - tow rig/DD
mathews8pt is offline   Reply With Quote
Old 07-15-2010, 08:56 AM   #3 (permalink)
would you believe I can't even move the arm to full throttle with the engine off. Everything is locked up until the engine is running. I even tried with the key on and the engine off. Lock up.
Old 07-15-2010, 08:59 AM   #4 (permalink)
Got P7100?
mathews8pt's Avatar
It will be hard to move but it should move with the engine off. They can be pretty stiff
Hobie
Old 07-15-2010, 09:26 AM   #5 (permalink)
whoabeats's Avatar
as Im at the side of the engine I move the throttle from the left side as if you were hitting the throttle under the hood while your truck is running then grab it with your right hand by that braket, and move it to wot then hold it here with your left hand, with your right arm free to adjust the idle. This is literally something I can now do with my eyes closed, because I have adjusted it so many times
97 2500 4x4 5spd #0 plate autometer boost fuel pressure and egt, 4kgsk w/ 60#ers, 33" Retread BFG AT's , HX35/40 hybrid, DDM Tuning 6k HID's, 98-99 HD steering swap
whoabeats is offline   Reply With Quote
