47re vs. 47rh - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 07-08-2010, 01:01 PM Thread Starter
47re vs. 47rh
As my sig says, I've got a 97 with the 47re, and I love this truck. I've got a chance to buy a 95 4wd, xcab, AT 3.54, half the miles, really clean, and I could buy it with the proceeds of selling my 97 ( I don't need, nor can afford, two trucks). Is there a major difference between the re and rh (mostly hydraulic vs. electric, this I know), as far as performance and reliability? Does the rh wear out faster, or not shift as well?
97 2500 4wd, AT, 3.54, 560k +, stock except for AFE filter and BD steering brace.
deezldude is offline
post #2 of 6 (permalink) Old 07-08-2010, 03:50 PM
So the question is???
9612vinva's Avatar
correct me if i am wrong but both transmissions run the same shafts and clutches...
Pretty but the same minus the hydraulic/electric stuff...
I also believe the fastest diesel truck runs a 47RH transmission...
97 ECLB Manual...2ndGenDoms trucks EVIL TWIN
Originally Posted by v8440 View Post
There's a guy floating around here with 780k on his unrebuilt cummins. Now, according to duramax and ford guys, his truck should have fallen completely apart around the engine 7.8 times, since they all know that dodge trucks are junk and only last 100k before they spontaneously disassemble themselves while going down the road. That has happened to me 2.76 times, and both times I was only wearing boxers while driving so it was really embarrassing.
9612vinva is offline
post #3 of 6 (permalink) Old 07-08-2010, 04:06 PM
ykdave's Avatar
Yes, from what i have read, its basically the same trans.
And yes, typically the mechanical things in this world are less problematic, granted they are set up correctly.
ykdave is offline
post #4 of 6 (permalink) Old 07-08-2010, 04:51 PM
glfredrick's Avatar
Same parts and same repair manual. Just computer-contolled shifts that you can do with a valve body fix just as well.
1995 D2500 4x4: #10 fuel plate, BHAF, turbo orfice, AFC forward, 3000 GSK, pyro & boost ga. NEXT: trans ga & filt, 4" exhaust, billet TQ, valve body.
UCORA.org -- United Christian Off-Road Alliance.
glfredrick is offline
post #5 of 6 (permalink) Old 07-08-2010, 11:10 PM
JakeDiesel's Avatar
how would u tell the difference between the 2 by looking at them r the plugs different and if so how
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
post #6 of 6 (permalink) Old 07-08-2010, 11:18 PM
ykdave's Avatar
different plugs yes (more wires on the RE obviously)
Check here at the bottom of the page for deciphering the numbers on the trans
Auto trans specs - Dodge Ram pickup
ykdave is offline
