1997 Auto Trans Shifts early - Help! - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 06-28-2010, 04:46 PM Thread Starter
There are so many tranny questions on here I am having a hard time finding a possible solution to my problem so I though I would just ask again. I have a 1997 2500 4x4 with the automatic trans. The issue I am having is that when I start from a stop sign, the trans will shift into 3rd gear at about 10 to 15mph. I had issues with the governor pressure stuff, (pulled a code out of the PCM) but I fixed them and the code has gone away. I am still left with this problem. When I shift it manually it works fine but as I said before, I can start at a stop sign, get the truck moving, then a violent shift into third gear and the truck is a turd again. Any ideas? Thanks in advance for the help.
03 3500 LBDRW, 4WD, 6M, HO, South Bend DD, Edge Juice W/ Attitude, FASS, - Sold
98.5 3500 LBDRW, 4WD, 4A, Bone Stock
03 3500 SBSRW, 4WD,6M, HO, Stock
Bigsteve94 is offline
post #2 of 11 (permalink) Old 06-28-2010, 10:07 PM
I have to assume it is a 47re not rh, if it is an re (e=electric) i would replace 2 things (gov.pressure solinoid & pressure transducer) that will fix your problem. Both located on the valvebody easy to change.
GL
sachsedodge is offline
post #3 of 11 (permalink) Old 06-28-2010, 10:13 PM Thread Starter
GL
i already replaced those, read my thread, those throw codes when they go.
post #4 of 11 (permalink) Old 06-28-2010, 10:16 PM
rtc1184's Avatar
sounds like the tc is locking is the issue. like someone put a tc lockup switch in and its on all the time.
01 24v 3500 single wheel nv5600
96 built 12v tow truck dually
06 mega cab with some goodies
rtc1184 is offline
post #5 of 11 (permalink) Old 06-28-2010, 11:12 PM
I know you said you replaced them but i have replaced a thousand of them from (no codes) manuel shift ok, D not ok, could you have replaced the O/D solinoids instead?
The thud is a failsafe (limp-in mode)3rd gear and reverse
Maybe a faulty speed sensor? or TPS?
post #6 of 11 (permalink) Old 06-29-2010, 05:08 AM
A violent shift is not normally a good sign in an automatic. The violent shift many times is caused by excessive clearances. When you take off, do you have both 1st and 2nd gears? Have you checked your TV (throttle valve) cable and made sure it is both working and adjusted properly? This cable has a lot to do with 1st thru 3rd shifts. I have had limited success with unplugging the PCM directly for about 20 minutes and letting it "reset" itself. When you shift manually (I know you said it is fine) how harsh are the shifts then? Are they harder than they use to be? How is OD and converter lockup? Have you checked to see if converter is locking too soon? Is there anything else not working properly on the truck (even if you don't think they're related)? Since you have a part electronic, part hydraulic trans, there are many factors, both internal and external, that can cause bad shifts on these trans. If you don't have a factory service manual, I strongly recommend one from Geno's Garage ($30 on CD). There are over a hundred pages devoted to just this one trans for both diagnosing and repairing.
RPegram is offline
post #7 of 11 (permalink) Old 06-29-2010, 08:17 AM Thread Starter
Keep in mind, i had to pull the code out of the computer, the check engine light did not come on for that one. regardless, i had a different problem prior to replacing the governor solenoid and transducer, The problem was that it would always start in 3rd gear, i can understand limp mode at that point as well. Regarding the speed sensor, i was getting a code for that as well (no MIL), when I crawled under the truck to replace the governor solenoid and transducer, I found the speed sensor was unplugged. I plugged it in, and the code went away. I still have overdrive.
post #8 of 11 (permalink) Old 06-29-2010, 08:30 AM Thread Starter
It is only violent if i am getting on it from a start. Normal acceleration is not an issue, nor is manual shifting. While shifting manually, its like a dream, just more work. i've only had the truck for the last 6K miles and the tranny has always had this issue. I've corrected some of the issues but this still remains. Overdrive is fine.
How do i check the lockup?
The only other issue i know of with the truck is that sometimes the crank sensor goes on the fritz. I know this is related to the transmission but before everyone jumps my case about it let me explain why i haven't fixed it. I know when the sensor is faulting out because the tach jumps around like crazy, the dash lights flash, and the trans will usually shift into a higher gear, once it starts working again (for whatever reason) the tach starts working, the dash lights go out and the tranny will shift again.
I have never screwed around with the tv cable.
Thanks for the help to this point guys, i appreciate the interest in getting this problem fixed.
post #9 of 11 (permalink) Old 06-29-2010, 06:45 PM
Is there any way to contact previous owner and see if trans has had any mods done to it? Ask about things like shift kit, valve body, stock valve body modified (drilled out) etc.
To check for lockup, once you get in the last gear change, keep steady pressure on go pedal and lightly depress brake pedal. You should see a change in RPM's. Once you let off brake pedal, the RPM's should drop back down. If your TPS is way out of adjustment, you could just be getting OD and converter too soon from just this.
You need to address the ESS (engine speed sensor). I believe when this acts up it is affecting the trans shifting and not the other way around. This sensor gives vital information to PCM to help it control shifts. When PCM gets bad signal from ESS, it will in turn give bad signals to other things.
I will also throw out there that you can have a bad governer pressure sensor and/or solenoid and never throw a code. If PCM doesn't realize it is getting bad info, it won't sound an alarm.
Here are some pics with instructions on how to check the TV cable. The adjustment of this cable is extremely crucial to making you trans live a long happy life.
RPegram is offline
post #10 of 11 (permalink) Old 07-01-2010, 11:59 AM
jcw74801's Avatar
Here's some info from Dunrite on shift points:
Dunrite Converters :: Frequently Asked Questions
1998 12v 2500 QC 4x4 3.54, KDP AOK, BHAF, gauges, 4" Diamond Eye, Goerend triple disc, Transgo VB, billet input, 3k GSK, 5x.012, 100 plate
jcw74801 is offline
post #11 of 11 (permalink) Old 07-02-2010, 10:09 AM
Have you checked the voltage at your TPS at idle? The TPS controls your gov. pressure and if adjusted incorrectly it can cause your issue (possibly). If you are over one volt that may be your issue. Mine is set low at .53 volts, many people will liekly jump in and say higher is better, but every transmission is different. Alos verify your TV cable adjustment as shown above. PS, fix the crank sensor issue too!
97 cummins with automatic
stone-cold is offline
