WIRING--94 12 valve in a older 72 chevy truck - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 06-26-2010, 09:12 PM Thread Starter
B_Schutz's Avatar
The 94 cummins is totaled, the motor and trans survived and I was wanting to transplant them into a old 1972 chevy truck. What is the best bet to hook up the wiring??
I saw on gears that Stacy David had PPE setup a duramax to run in an old international cabover, but whos the go-to for 2nd gen cummins??
2004.5 HO325 QCLB, 4x4, DRW, Goerend, smarty, 3.73s, 5" MBRP, studs, honed Bosch 150s, AD150, 64/71/14ss over S480ss twins
B_Schutz is offline
post #2 of 3 (permalink) Old 07-07-2010, 02:00 AM
12VF250's Avatar
This probably the easiest wiring job you will ever do..... The fuel shutoff solenoid has three wires, white, black, red. Black goes to ground, Red goes to a key-on power source, and White goes to the small terminal on the starter solenoid. Add a couple of battery cables, positive to the big terminal on the starter, negative to the block, and it will run. On the back of your alternator, there are two small posts with wires connected to them, and one large post. The large post goes straight to the positive battery post. One of the small posts gets grounded to the case of the alternator, and the other one gets connected to the "field" terminal of a external voltage regulator. I like to use old Ford regulators. They have four connectors in them labeled I A S F. The I is useless, and doesn't get connected to anything. A terminal gets connected to the positive post of the battery. S terminal gets connected to key on power. The F terminal gets connected to one of the small posts on the alternator. It doesn't matter which one gets grounded and which one gets field from the regulator, it will work either way.
'96 F250 SuperCab w/ '94 6BTA S362/S480 compounds, A1studs, 5x.014's, 191's, 2095 plug, AFC mods, no plate, 4KGSK, Airdog 150, 60lb valve springs, 18*, Banks Techni-cooler, NV4500, KDP tab'd, Valair clutch, BD exh brake, 572hp/1103tq @ATS Diesel, Denver, CO 3-3-12
12VF250 is offline
The Following 2 Users Say Thank You to 12VF250 For This Useful Post:
cmnspwr (10-07-2010), conway (01-16-2016)
post #3 of 3 (permalink) Old 07-07-2010, 09:39 AM
GAmes's Avatar
iTrader Score: 7 reviews
Since the 67-72 Chevs are basically the same, I'm wondering if the front end will support the weight of a Cummins. I have a 67 C20 and know for a fact that the C10 has a lighter duty frame. I found that out when I had to notch my frame to install headers (my son had a 71 C10 at the time). I'm not sure the rear wishbone suspension would hold the torque either.
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
