Charging and Tach Problems , ANYONE KNOW THE REAL FIX?
Tach cut in and out , And when it does it stops charging , i've searched and searched , everyone says crank position sensor , So i changed that 120 bucks later the POS is still cutting in and out ......So i cleaned every connection on the truck cleaned the plug into the ecm . She worked for about 100 miles , I drove non stop to see if it would cut out . As soon as i stopped at a gas station came out started it . ITs dead again . No tach not chargin . Anyone know how to fix this pos ? Its a 94 2x4 with a auto
94 2500 sc/lb ,221k ,Built Trans , #10 fuel plate, 60lbs springs, tuned afc ,3 gsk ,16.5 timing, 2" leveling kit , 285 Michelin at2's
98.5 24v DRW 4x4 3500 qc,lb,170k, "Hand Shaker" , 100 horse fte injectors ,Edge JWA/CS ,New Injection Pump , Fass 95 ,Banks Exhaust Brake,Monster Ram Intake 5inch Exhaust , Bhaf, DT Control Arms +1/2 inch and 2.5 inch Superlift Springs , 285 Mich at2's , Bradford Built Bed
Ac still works apeedo works , everything works but tach and charging , all wires are good .....I need this thing running , gotta head tyo ogden utah first thing friday .........
I may be way off base here, but I've heard of a fix using an older volt regulator. I believe the volt regger is in the computer on yours, the computer starts to fail=no charge.Heres a link that may be useful.
Sometimes the obvious eludes us so forgive me for saying this, and please don't take offense, but how are your battery terminals? If they need cleaned or tightened or stuff it can do weird stuff to the electrical system.
2001 Dodge Ram 2500 reg cab 2wd. Dr. Performance Stage 5 box, DDP stage 1 injectors, Valair 12.25 single with ceramic buttons and upgraded hydraulics, straight piped and de-badged, ARP Head Studs, pink Lone Star Diesel Intake Horn, pink HDP Custom Differential Cover
I had the EXACT same symptoms as your describing. In addition sometimes my wait to start light, check engine light wouldn't turn on for a few seconds during initially turning the key on. It is rare but mine ended up being a bad computer. Mines a 95 and 94s had the same computer. Try car-part.com to find a new computer or oreilys auto parts. I got mine used through car-part.com for under $150 shipped. Oreilys supposedly sells new ecus.
95 dually auto ext cab Laramie 365k miles, 4k GSK & exhaust valve springs, BHAF, boost elbow, no plate, modified and tuned AFC, rebuilt and ported stock HX-35W, 4" Diamond Eye exhaust, Pyro, boost &, trans gauges! Power 2003 club cab seats!
My 94 did the same thing, but the engine speed sensor fixed it. Did you set the gap correctly? Too much clearance could cause an intermittant signal.
x2 I just had to do this a couple days ago. Had the same problems as you and it cured it. The gap is supposed to be between .049"-.051" and mine was at .065"
Reset the gap to .051" and she runs like a charm now
~1997 Extended Cab Long Bed 12V Auto -silencer ring MIA, Straight Piped (should have never sold her)
~1994 Regular Cab 3500 4X4- All stock and finally got my 5 speed
have a buddy with a 98.5 exact same prob, he had tried everything, but i dont think he knew about the gap deal, ill run it by em, he is gettin so mad tomorro he was goin to wire it up so it charged at all times, so that way he wouldnt have to worry bout finxin it, lol maybe not tho if he tried gapin it and it works
03 3500 , Srw-Qclb, 6 spd, 4X4, Afe Stage 3 Intake, Autometer Cobalt -Fuel Pressure,Boost,Egt,Rail Pressure, Southbend DD 650-Hydros, Smarty S-06 Pod TNT, WAMP 95/95 Soon To Be Upgraded, Scheid 90 Hp Sticks, 5" Straight Pipe... Cosmetics..
