94-98 Auto Tranny.. - Dodge Cummins Diesel Forum
Old 07-28-2007, 12:59 PM   #1 (permalink)
greg@Lockitup's Avatar
94-98 Auto Tranny..
Probably a newb question that I could search and find but here goes..
Is the 47RE the only model auto tranny that came in these trucks?
www.lockitupoffroad.net
2003 Cummins SLT 2500 QC
1996 Cummins CC 2500 4x4
greg@Lockitup is offline   Reply With Quote
Old 07-28-2007, 02:21 PM   #2 (permalink)
cjensen91910's Avatar
94 and 95 came with a 47rh rather than an 47re.
95 Auto, billet TC and modded valve plate, BHAF, Aux lift pump, three position lockup switch, full gauges, #5 plate, no muffler and CAT is gutless. Timed at 15.5, full EGR brake package.
cjensen91910 is offline   Reply With Quote
Old 07-28-2007, 05:19 PM   #3 (permalink)
Was the 47rh plagued with the same historical problems as the 47RE?
Old 07-28-2007, 06:09 PM   #4 (permalink)
The difference between the two transmissions is the governors. The 47RH has a mechanical fly weight governor. The 47RE has a computer controlled governor. This, of course, means that the valve bodies are different. The rest of them are just about the same with minor differences.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit.
Joe G. is offline   Reply With Quote
Old 07-28-2007, 06:19 PM   #5 (permalink)
Thanks! Exactly what I needed to know!
Old 07-28-2007, 06:53 PM   #6 (permalink)
Tranny types
Basically the alphanumeric ID's work as such
First field = number of speeds
4 = 4 speed
3 = 3 speed
second field is a torque rating, not sure how they rate these but it's a scale of 0 - 8
Third field is the DT config, so
R = Rear wheel drive
A = All wheel drive
T = Transverse mount
L = Longditudinal mount
Fouth field is the control system
H = Hydraulic
E = Electronic
So as mentioned in the last post a 47RH is a 4 speed 7 rated (torque) rear-wheel drive hydraulically controlled tranny
47RE is a 4 speed 7 rated rear-wheel drive electronically controlled tranny
They starting using these types of identifiers in 1992
Cheers.
1990 Dodge D250, 4" Exhaust, 16 cu. cm (WG) Turbo Housing, AutoMeter UltraLite Gauges, Modified Fuel Pin, Power Screw at Max, Re-Building a TF727 to replace stock transmission
euid is offline   Reply With Quote
Old 07-28-2007, 09:01 PM   #7 (permalink)
Cool. I'm really wanting to find a manual tranny 94 to 98 model but from what I've heard it's needle in a haystack pickings on those..
