Fan nut size?? - Dodge Cummins Diesel Forum
Old 07-22-2007, 09:45 PM   #1 (permalink)
Banned
Fan nut size??
What size is the fan nut on a 1997 12V?? Loosen is clockwise as looking at the front of the engine correct?
zstroken is offline   Reply With Quote
Old 07-22-2007, 09:51 PM   #2 (permalink)
This account not in use anymore!!
wtfd6's Avatar
mine is a 36mm. I believe the 12v is the same. and yes it is clockwise facing the engine. the other way of telling on the fan is, look at it and see what direction it turns. they go the opposite way to come off, for the most part. there are exceptions.:thumbsup
2000 Ram3500
MaumeeValleyPullers
Proud Member Of The Ohio Coal Rollers
wtfd6 is offline   Reply With Quote
Old 07-22-2007, 10:23 PM   #3 (permalink)
Banned
How are you holding the fan hub??
Old 07-23-2007, 05:37 PM   #4 (permalink)
There are special tools that grab the hub bolts to hold it.You may have luck hitting the wrench a sharp wrap.
Bob
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
bob4x4 is offline   Reply With Quote
Old 07-23-2007, 05:48 PM   #5 (permalink)
louielouie's Avatar
Park Tools sells a thin 32x36 m/m wrench for bicycle headsets (any bicycle shop) - I use it to loosen the fan nut on my Bimmer (which is 'reverse' threaded) by "tapping" it with a metal (not composite) hammer/sledge to break it loose.
'07 2500 5.9L SLT QuadCab shorty 4x4 w/48RE with Rokktech crnk snsr, PUSHER intake, Quad boost fooler, Baldwin f/f, Donaldson o/f, Amsoil By-Pass
louielouie is offline   Reply With Quote
Old 07-23-2007, 06:10 PM   #6 (permalink)
AlGores worst nightmare
Racer9's Avatar
My method; Before removing the belt, clamp a vise-grip on it (not too tight), sticking out towards the drivers side. Get a 2X4 a foot and a half (or so) long, and place the end against the vise-grip. Whack the other end with a hammer. It should break loose easily.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 07-23-2007, 09:44 PM   #7 (permalink)
Banned
It isn't a 36MM. I am having a terrible time getting it loose. I have a fan removal tool which is holding the fan very nicely, just can't get the nut to break loose. Clockwise looking at the front of the engine to loosen the nut correct??
Old 07-23-2007, 11:05 PM   #8 (permalink)
ISX
ISX's Avatar
I just took a punch to the edge of the nut, beat it good once and it was loose, nothing was holding anything back except the regular tension of the belt... I think it is 1 7/16" ... And yes, if you are at the front of the engine looking at it and the wrench is on the right, yes beat it down..or clockwise.. it will come
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 322k miles #100 plate, SB Con O, 26.6MPG-55mph
ISX is offline   Reply With Quote
Old 07-28-2007, 12:57 AM   #9 (permalink)
You could just use an air chisel. If you do it right, it doesn't remove much material at all... Works great too!!!
1998 2500 Ext Cab 12 valve Auto 4x4, 15.75*, Pensacola Stage 1s, 4" Turbo Back Exhaust, K&N Replacement Filter, Di Pricol Gauges, #10 Plate 1/2 back, Goerends Tranny w/ Triple Disk TC & new VB, w/ VBA
tachessher is offline   Reply With Quote
Old 07-28-2007, 10:22 AM   #10 (permalink)
Banned
Thanks for the advice. I finally got it. Had to vice grip the pulley against the cover and swung at the wrench with a 2x4. After about 5 minutes once I got the pulley to stop moving it broke loose. Was tough coming all the way off. Trying to figure out why, I have had it off 2 other times. Wandering if the 4000+ rpm really snugged it on there.
