I've tried searching, but I can only find out where to install temp sensors on auto trannys. Can I plug into the stock trans temp sensor, thats what the glowshift directions said that I may or may not be able to do. I'd really like to not have to drill any holes if possible, or am I just dreamin? Thanks
94 1ton, 4x4, nv4500, drw, flatbed, glowshift gauges, k&N air, banks fuel plate ff, afc ff, afc foot ground, cb, auxiliary fuel pump and filter, custom veg oil setup
Do you have to weld a bung onto the pto cover? Or could you just tap the pto cover? I know its prolly on the thin side but I don't see a temp sensor taking a lot of stress
Remove the PTO cover. Drill a very small hole where you want the sensor (make sure it stays below fluid level) and take a tapered drift punch (long punch that has small end and is tapered back to where you hit with hammer) and drive it in hole. Place the cover over something like a partially open vice to keep from bending pan as you drive the punch in hole. Keep removing punch until you can get a tap the size of sensor to start (most likely 1/8" pipe thread). Tap hole and screw in sensor. This will work on autos as well. Comes in very handy for installing a drain plug in factory pan without a plug already. This "rolls" the metal inside of cover and gives you a surface to put threads.
