Old 07-03-2007, 11:11 AM   #1 (permalink)
Tq converter shot or complete transmission? How can you tell?
First of all, you all have been VERY helpful and I really do appreciate it. Ive gotten a lot of good advice and help from yall. Some of the things I have been reading, however, are leading me to believe that, since the TQ converter is such junk in these rigs, that often times IT is the failed part alone? How can you tell? Are there certain characteristics, RPMs, shifting issues, fluid?
Im just wondering if that might not be the issue, seeing as how my current tranny was just rebuilt 10/06. (Just wanted to use it! )
1996 12valve, Auto, single cab, 2in pucks in front, rollin on 305's. BHAF, straight piped. EGT, Boost, and Tranny temp guages.
HELL NO IT AINT GOT A HEMI!
mavrik4x4 is offline   Reply With Quote
Old 07-03-2007, 11:20 AM   #2 (permalink)
MS Chapter President
2141pete's Avatar
Mine would shutter really bad under lockup. I think I could have maybe done a TC and VB and been ok but I had the money so I went for the new tranny too
02 QC,4x4,TRE auto,AD150,BD twins, Mach5's,F1 springs,o-rings, studs,Quad ADR,smarty, Stewart warner gauges, a small shot of nitrous
12.71@104 #2 only 569/1080
2141pete is online now   Reply With Quote
Old 07-03-2007, 11:43 AM   #3 (permalink)
Moderator
pro99's Avatar
Was it rebuilt to stock or any aftermarket goodies?
Charles Estep
pro99 is offline   Reply With Quote
Old 07-03-2007, 12:09 PM   #4 (permalink)
No sir. All stock at the Chrysler dealership.
Old 07-03-2007, 12:40 PM   #5 (permalink)
Moderator
pro99's Avatar
You can have a convert causing concerns like stalling when put into gear, high RPM's when taking off with soft shifts, shudder going into lock-up or no lock-up at all, stalls when coming to a stop, yes the fluid would be dark with sings of metal flakes in it. When you say the converters are junk in these trans its not they are junk they are not built for higher tq and hp. You have to understand that raising line pressure to a point helps the T/C to live longer too. Also keeping temps down plays into this too.
Hope this helps
Charles Estep
Old 07-03-2007, 12:47 PM   #6 (permalink)
No, its not doing any of that(yet). When in any gear above 1st and holding it at steady throttle, it will revv up a few hundred rpms and then come back down. Like pushing the clutch in slightly on a M/T.
Old 07-03-2007, 01:08 PM   #7 (permalink)
Moderator
pro99's Avatar
Well if a T/C is slipping it will slip all the time when not in lock-up, It sounds like you have another concern going on. What you may have going on here is called lock unlocking of the T/C. It could be the TPS, Voltage spikes from the alternator,engine +trans Temp sensor, Lock-up Solenoid, Battery's or Bad connections at the Battery, RPM spikes, PCM re-flash, Bad speed sensor on the trans O/D unit and or speed signal from t-case.
Charles Estep
Old 07-03-2007, 01:15 PM   #8 (permalink)
Hmmm. Oddly enough, I had the water in fuel light come on about 3min. before this started. I wonder?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
