please help the newbie - Dodge Cummins Diesel Forum
Old 03-14-2010, 08:13 PM   #1 (permalink)
Question please help the newbie
so i might buy a 97 tomorrow and he thinks the turbo is junk! he says the turbo doesnt whistle and thinks its noo good so how do i tell if this is correct and wat turbo should i replace it with and price range thanks for all the help
Not sure wat im getting yet hopefully ill kno soon. stil shopping for the right truck
damour4x4 is offline   Reply With Quote
Old 03-14-2010, 08:19 PM   #2 (permalink)
JohnBer's Avatar
get it to a mechanic and have him check it out. On my stock turbo, exhaust, airbox with the silencer ring in i could barely hear it. If it is bad ya can pick up hx 35's pretty reasonable. or get a used one off one of the forums.
Dog's truck:95 2wd ex, built auto, kdp tabbed, 3 disc billet converter,3.54 gears, 4gsk, bhaf, 0 plate, rack plug, 90hp injectors, 191 DV's, htt 62/71/14, timed @17*, 60# valve springs, head studs, 4" exhaust, gauges
JohnBer is offline   Reply With Quote
Old 03-14-2010, 08:20 PM   #3 (permalink)
Take the intake hose off and check the shaft for play. Up and down is fine as long as impeller doesn't hit the housing. Also, look for signs of oil. You may have to take the clamp off bottom going to cooler to check it well for oil. If it still has the silencer ring in it, it will be fairly quiet, but not bad.
RPegram is offline   Reply With Quote
Old 03-14-2010, 08:54 PM   #4 (permalink)
ykdave's Avatar
sounds pretty normal...
stock, you cant hear the turbo whistle and they dont have enough power to get out of their own way.
Even if the turbo is f'd, they are easy enough to rebuild/replace
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
Old 03-14-2010, 09:17 PM   #5 (permalink)
95dually3500's Avatar
check the shaft for play like said above,take it for a drive and see how it runs, They arent bad to replace and if you have a plan for more power than buy a better than stock turbo for it. Give us some more details on the truck- 2 or 4wd,auto or manual,miles,condition,reg cab,ext cab etc,whats he asking for it
96 2500 Reg Cab 4x4 - AFE Stage 2 Intake, Pusher intake 4k GSK,ground plate, pump tuned,fass 150 , Autometer-Gauges,Built auto w/Goerand Tripple,Disc
ED BIllet 66/68/.8 & 5x14's SDX Comp DV's 17.5* timing,
95dually3500 is offline   Reply With Quote
Old 03-14-2010, 09:42 PM   #6 (permalink)
diggerphd's Avatar
Turbo rebuilds
Bill, aka Illflem, the mechanically well versed Montana rancher, mentioned earlier a company that rebuilds our turbos. The company is High Tech Turbo and their phone number is 801 304-0700. High Tech Turbo
Bill said they charge about $70.00 for a re-build.
Welcome to the club!
Regards,
Steve
1996 Dodge Cummins 12V, Stock 2 WD, 5-speed, Cummins exhaust brake, 152K, KDP Dead! Standing in the "500K+ reliability & best fuel economy" line If I want speed, I'll race you in my 'ol Cessna!
diggerphd is offline   Reply With Quote
Old 03-15-2010, 12:04 AM   #7 (permalink)
I want to marry my truck
madmikeismad's Avatar
You'll know if the turbo works, when you floor it. It's gutless, then it spools and slides you back in the seat a little.
Purple People Eater - Low and poorly tuned. http://picasaweb.google.com/mch8223/Diesel#
The Race Truck - New drag truck with big plans!
https://www.youtube.com/user/THEmadmikeismad/videos
madmikeismad is offline   Reply With Quote
Old 03-19-2010, 07:17 PM   #8 (permalink)
deezall's Avatar
make absolutly sure there is not any oil in the intake system it can cause a run away issue. had one at the dealer i worked at and well the x-ray kinda tells the rest of the story!
96 extclb12v 4x4 5" exhaust, k&n, a few dents and dings for character, ground fuel plate(bout to go mia), lopped off afc foot and starwheel ,5k gsk, slush box with shift kit 17ish* of timing.
deezall is offline   Reply With Quote
