Old 06-28-2007, 07:34 PM   #1 (permalink)
vaicase's Avatar
Question wheel cyl upgrade?
i read something about putting gm wheel cyl on the rear of the dodge trucks.what is the part number and where do i buy?another question i have what about putting 1 ton rear wheel cyl on it?i have 13x2.5 the one tons are 13x3.5 just wondering?thanks
1995 dodge 2500 2wd3.55gears 235/85/16 tires/nv4500-5speed k.d.p.tabbed,pyroandboost,bhaf ,4 inchturbo back no muffler 6 inch stack,watchout,rust never sleeps,.love that cummins
vaicase is offline   Reply With Quote
Old 06-28-2007, 08:23 PM   #2 (permalink)
guroo987's Avatar
the napa part #4637337 as afr as the other question, i dont think so, but someone will know for sure.
http://www.cumminsforum.com/images/cf_premium_promo.jpg
99 4x4 2500 longbed extra cab, 24 valve ctd, bhaf with outerwear and heat shield, edge juice with attitude , vulcan big line pump relocate kit with holley blue , mechanical fuel pres guage ,straight piped, automatic overdrive, 2 inch leveler lift, 17x10 ion rims with 315/70-17 bf goodrich at's ,bug shield, nerf bars, and other misc.
guroo987 is offline   Reply With Quote
Old 06-29-2007, 06:21 AM   #3 (permalink)
That part number is for a one ton GM truck. I dunno about putting Dodge Ram 3500 wheel cylinders on there...
1998 2500 Ext Cab 12 valve Auto 4x4, 15.75*, Pensacola Stage 1s, 4" Turbo Back Exhaust, K&N Replacement Filter, Di Pricol Gauges, #10 Plate 1/2 back, Goerends Tranny w/ Triple Disk TC & new VB, w/ VBA
tachessher is offline   Reply With Quote
Old 06-29-2007, 08:44 AM   #4 (permalink)
Tech Specialist
make sure uit is for a dually, the single wheels use the same one as ours.
97 dually 500 plus, 98 quad 12v wifes, and the toy a 98 reg cab short bed with a hx40 and ht3be
gunracer1 is offline   Reply With Quote
Old 06-29-2007, 10:34 AM   #5 (permalink)
Moderator
p/n 37337 at any autoparts will give you 23% more braking power than the stock '94 Dodge 3500 cylinders.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 06-30-2007, 09:50 PM   #6 (permalink)
vaicase's Avatar
Cool
wrong.i was told by napa that that part number is for metric threads.and its only1and1/16.when i read on these sites it is 1and 3/16.i went with 1ton dodge1and1/16.the ones i took off were15/16.i dont know if they were original or what.i got them from napa.a little over 20.00 for both with tax.thanks
Old 06-30-2007, 09:51 PM   #7 (permalink)
vaicase's Avatar
Thumbs up
also i could be wrong.so someone tell me if i am.thanks
Old 07-01-2007, 09:33 AM   #8 (permalink)
Moderator
The Napa guy was wrong.
That's why the only info you should give them is the part number, all they do with more info is screw you up.
#37337 are larger diameter than any cylinder ever used on a CTD
Bill
'95 2500 4wd auto
Both far from stock
Old 07-01-2007, 12:22 PM   #9 (permalink)
tractorpuller's Avatar
Yep #37337 worked for me. Just went to napa and gave them the part #.
97 extendedcab 4x4 auto;18*timing;SFS custom tuned afc custom ground plate;3k gsk; ISSPRO guages, 4" straight piped, bhaf, b&w gooseneck hitch, prodigy brake controller, kdp kia
tractorpuller is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
