Help! Chevy/Cummins Conversion - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 02-11-2010, 12:27 PM Thread Starter
Murdog's Avatar
Question Help! Chevy/Cummins Conversion
Hi All, Has anybody used or in favor of the motor mount/crossmember piece from Avalanche Engineering for 1973-91 Chevy conversion
[SIGPIC][/SIGPIC]
91 Chev V3500 3+3 Crew Cab (straight axle front)
87 Chev K30 Blazer (converted to 1 ton)
93 Dodge D350 Cummins Dually
97 Dodge 2500 Cummins (Donor)
89 Dodge D250 Cummins (Donor)
Murdog is offline
post #2 of 13 (permalink) Old 02-11-2010, 12:38 PM
wcuhillbilly's Avatar
Use the mounts from the Dodge frame,,,, the 24v rattle alot more than the 12v, thus the biscuits are better,,, the GM mounts for either big block or 6.5 are not going to hold up very well. I grafted the stock cummins mounts into my chevy frame and built an under engine crossmember from 3" channel Iron. It dont look pretty, but my frame doesnt flex..... I looked at the Avalanch method and had my doubts about it holding up to the rough service and abusive conditions that I put my trucks thourgh. the engine/frame mounts for the GM was my biggest concern...... Avalanch also says to mount the intercooler upside down in the core support... I mounted mine the dodge way, and reinforced the core support with 1" tubing, the radiator fits alot nicer with the intercooler positioned correctly.
2001 24v P-Pump Cummins, NV4500/NP205 transplant, 85 K30 CrewCab Dually D60, 14 Bolt 3:73....ATS Pulseflow, Banks Intake. BD I/C Boots, Jake Brake,(slightly modified) Studs, DDP 75hp inj, PDR HX35 HybridBuilt, NOT BOUGHT !!!! M816 Wrecker NHC 855 small cam Cummins
wcuhillbilly is offline
The Following User Says Thank You to wcuhillbilly For This Useful Post:
Murdog (02-11-2010)
post #3 of 13 (permalink) Old 02-11-2010, 02:10 PM Thread Starter
Murdog's Avatar
Avalanche crossmember
What was avalanche's reason for mounting the cooler upside down
[SIGPIC][/SIGPIC]
Murdog is offline
post #4 of 13 (permalink) Old 02-11-2010, 06:00 PM
I have no earthly idea,,,, I called them 2 years ago when I was getting reddy to do my conversion. He said mount it upside down to fit in the core support better. From what I can see, the intercooler is shaped to come out from around the Radiator specifically at the bottom of the radiator.... if the intercooler is positioned upside down, then the upper portion of the radiator tanks is in conflict with the intercooler..Not to mention the batteries are in the upper region of this area too.... I found alot of people bashing Autoworld in MT, I cant say Ive ever had anything worked on by them,,, but they were helpful when I called and pick'd their brain every now and then... I have a partial write up of how I set mine in and wired up the 24v, I can send it to you via email if you like.
Murdog (02-12-2010)
post #5 of 13 (permalink) Old 02-12-2010, 03:10 PM Thread Starter
Murdog's Avatar
Cooler
That would be great if you could send that
[SIGPIC][/SIGPIC]
Murdog is offline
post #6 of 13 (permalink) Old 02-12-2010, 11:03 PM
Check out Tennessee Diesel Conversions. I'm in the beginning stages of doing this conversion also. You can see their crossmember here: Tennessee Diesel Conversions - CK5 Forums I also only live 10 miles from Avalanche Engineering and will be stopping by there next week. I've seen there work up close and can say that it is very clean and professional looking.
nightmare73 is offline
The Following User Says Thank You to nightmare73 For This Useful Post:
Murdog (02-15-2010)
post #7 of 13 (permalink) Old 02-12-2010, 11:09 PM
I think the difference between the two is that the Tennessee doesn't require the truck to be lifted where as the Avalanche a.k.a. De-Stroked requires at least a 4" lift. The Tennessee also costs more.
post #8 of 13 (permalink) Old 02-13-2010, 01:06 PM
Know a guy via a friend/coworker of mine back in NC, that spent over $10,000 with Tennessee conversions,,,, his truck still isnt right. He procured the donor truck, and dropped his off with them. My guy has had to work on the clutch a couple of times, and the trans sounds like its grinding nails all the time,,,, called Tech about it,,, they said its supposed to
The reason the truck needs 4" of suspension lift (you can get by with 2" on 4x4) is for the oil pan to clear the front axle... most of these guys will tell you, "you will need to lift it 3" of body lift" I didnt, I cant stand body lifts, for the aspect of complicating the center of gravity and making it extremely topheavy,, Ive run a few of them, I run hard and fast, I want my body tied to the rails, especially in a rollover(previous experianc) Yes it is much easier to install the engine if there is a body lift on,,, My application was specific, thus for me a body lift doesnt work. for you it may.
Ive asked Crewcab59 a few times about this conversion back when I was rounding up the peices, the info that was given looked good on the surface but was peppered with "bring it to me" "buy my products, or wiring diagrams", kind of comments. I finally got fed up with the exclusiveness of the situation, and looked elsewhere. FordCummins was none better, I paid for the 24v wiring diagrams and write up from those guys, and found their instructions to be destructive. IE, splicing the engine harness at the ECM,,,, (this eleminates the chance of changing the engine harness on the side of the road if a short or partial engine fire ever occurs: heaven forbid you wired something wrong and it doesnt show up for 30,000miles???.) My wiring is spliced in before the 11 and 14 pin connectors of the engine harness, thus I can plug and play with any junkyard engine harness if need to...... Im not sellling anything so dont get that idea, anyone is welcome to the info and knowledge that I have aquired over the years. It is then up to the user to utilize said info or parts in a manner that works for them.
there are no shortcuts to this conversion,,,, you have to sit down and plan every move... biggest thing is that now you have a bastard truck that no one wants to touch and you as the owner driver must know, personally every inch of it, for when something happens, or goes down. Or be prepared to spend lots of denaro while the shop guys fiigure out your truck and basically learn it for themselves then start trying to figure out your conversion, and finally figure out the problem you are asking them to fix...
Murdog (02-15-2010)
post #9 of 13 (permalink) Old 02-13-2010, 01:19 PM
5.9 guy's Avatar
Just finishing up my 85 chevy cummins conversion, what ever you do dont cut any corners or try to hurry throught it.
02 2500 qcsb, p7100
5.9 guy is offline
The Following User Says Thank You to 5.9 guy For This Useful Post:
Murdog (02-15-2010)
post #10 of 13 (permalink) Old 02-15-2010, 07:54 AM Thread Starter
Murdog's Avatar
I knew it wasn't going to be easy
Thanks for your input guy's. I really do want this conversion to look professional. I go to a lot of offroad events and I know the truck will get picked apart. I'm still up in the air with transmission/transfercase combo. I want it to be a manual and durable.
[SIGPIC][/SIGPIC]
Murdog is offline
post #11 of 13 (permalink) Old 02-15-2010, 01:13 PM
Murdog:... PM'ed you back with my 24v Cummins repower Documents, and Install pics,,,, hope your connection speed is good and the memory of your computor is free.....Lots of stuff there to absorb..... enjoy....
as far as tranny goes,,,, mine is the NV4500 off the 24v cummins in the pics.... it was mated to a mid 80s Dodge NP205 case off an old (cant remember,) Chrysler 727torqueflite or Getrag 5spd, from a Cummins,,, This particular case,(was built with mix of GM/Dodge guts) will mate to the NV4500 tail. (AA makes an aluminum kit for around a $Grand that does the same from a GM TH400 version of the NP205, with machining required). and there is a $75 coupler that was made by dodge that would connect the splines between the two... this part is fabled over at Pirate4x4, and no one seems to be able to come up with a part #,,,, sorry to say I cant either,,, forgot to tell the shop that did my trans rebuild to look for it while they were in there, and I dont feel like bench pressing a trans at -10*F just to look inside for a #..... I used AA's shifter braket for the 205 shifter linkage,,,, came back later and welded a coulpe supports to it, to keep the play out of the shifter, as the 205 will bind in gear and make it a pain in the rear to shift in and out of 4x4....
Murdog (02-15-2010)
post #12 of 13 (permalink) Old 02-15-2010, 01:34 PM Thread Starter
Murdog's Avatar
Thanks for all the Pics
I knew this dream was going to be expensive. How long did your conversion take?
[SIGPIC][/SIGPIC]
Murdog is offline
