Truck smells like coolant...no leak - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 02-01-2010, 10:46 PM Thread Starter
97RollinSmoke's Avatar
well basically like the title says the truck smells like coolant pretty bad but there is no leaks...of coolant that is lol. So i guess my question is where is it all going and whats wrong? Sorry idk much about this. All help is appreciated. Thanks
New: 2015 Black Mega Cab. 68RFE. 3.42s. Stock
Old: 97 x-cab lb,6"lift,35's,Built auto, Too much fuel, not enough turbo. RUST BUCKET 12VALVE
97RollinSmoke is offline
post #2 of 9 (permalink) Old 02-02-2010, 06:44 AM
A very small leak can cause that sweet smell of antifreeze in the cab. I've seen headgaskets, hoses, gaskets and heater cores all do it. Sometimes the leak is so small it won't even drip, but evaporate and leave a nasty green stain. This evaporation is what you are smelling. Pressure testing will help find leak. Do it with a cold engine and evaporation will be less of an issue. Sometimes the little leaks will even take a UV dye to help pinpoint.
RPegram is offline
post #3 of 9 (permalink) Old 02-02-2010, 11:35 AM Thread Starter
well i mean like i have only had the truck for maybe 3 months now and i have filled up my coolant twice lol
post #4 of 9 (permalink) Old 02-02-2010, 11:54 AM
Banned
check your heater core http://www.dieseltruckresource.com/d....html?t=229112
i thought for sure my headgasket was gone.... then one morning i noticed the antifreeze on my windshield...
EASY fix, takes about an hour or 2 depending on beer supply
Kronic_187 is offline
post #5 of 9 (permalink) Old 02-02-2010, 11:54 AM
Avatarless
Got wet carpet???? if not u might be lookin at gettin new head gasket/head. Cause that sure sounds like your burnin it off.......
2015 Ram 2500
2001 Ram 3500
Gone: 1995 12 Valve
,2013 Ram 1500 Crew Cab Express
honestcharlie56 is offline
post #6 of 9 (permalink) Old 02-02-2010, 09:09 PM
brickwahl681's Avatar
you may have such a small leak in the heater core that your carpet may not be wet but still smell like antifreez. I'd check the heater core if no lines are showing signs of leaking. You can put some florecent dye in the coolant, run the truck then shine a black light on it to look for any leaks under the hood.
brickwahl681 is offline
post #7 of 9 (permalink) Old 02-03-2010, 12:20 AM
I had a small leak under my thermostat housing that was unoticable, took a while to find it.
Arbortek is offline
post #8 of 9 (permalink) Old 02-03-2010, 10:57 AM Thread Starter
is there any specific spot my carpet would be wet?????
post #9 of 9 (permalink) Old 02-03-2010, 05:26 PM
If heater core is leaking in truck, then it would drip on passenger floor board. Many times you will smell them with just a little leak. Also, most times when heater core goes bad, you will start fogging up windshield.
RPegram is offline
