pyro sensor location - Dodge Cummins Diesel Forum
Old 01-26-2010, 05:59 PM   #1 (permalink)
WUTNOIZE's Avatar
when installing a pyro sensor where is the best location for it ...looking for some xtra tips u dont get in the instructions
1997 3500 Dually 4x4 ,5 spd, 241DHD,410's,#10 Plate,Tuned AFC, Ajustable Boost Elbow, KDP Jigged, , 4" Turbo back, 19.5 Alloy Wheels/245/70R19.5, Level Kit, 5100 Bilsteins,BDD Tracbar/Steer box stab , Poly Bushings, Isspro Guages Pyro-Fuel-Boost1Orig Owner
WUTNOIZE is offline   Reply With Quote
Old 01-26-2010, 06:09 PM   #2 (permalink)
RockandRollOffroad's Avatar
I Would Recommend Putting it in the exhaust manifold ( A central location would be best) before the turbo... be careful not to get any metal shavings down into the turbo! Put grease on the drill bit so it catches some of the shavings, and have a magnet ready to get the rest out of the inside of the manifold
2004.5 Ram 2500 4x4 5.9L Cummins to a NV5600... ARP Studs, Ported & Polished Head, Oversized Valves, Phat-Shaft Turbo, BD Injectors, FASS Platinum, Edge, Afe, Auto Meter Gauges, leveled on 35" Toyo's
RockandRollOffroad is offline   Reply With Quote
Old 01-26-2010, 06:14 PM   #3 (permalink)
I always tap into the exhaust manifold, about an inch or so back from the flange, and either go left or right ofcenter. That way you get pre turbo pyro readings. I would imagine there are pics all over this site that will give you an exact picture of where to go.
2011 2500 4x4 CCSB G56 all stock for now.
GMCummins is offline   Reply With Quote
Old 01-26-2010, 06:25 PM   #4 (permalink)
WUTNOIZE's Avatar
thanks guys for the info.. i did think about the grease on the drill and tap..i also like the magnet thing i was going to use some type of vacuum ...was looking for some tech threads on it
Old 01-26-2010, 06:55 PM   #5 (permalink)
AlGores worst nightmare
Racer9's Avatar
Here ya go: PDR Diesel Inc. The turbo diesel performance specialists! - Pyrometer Probe Installation
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
The Following 3 Users Say Thank You to Racer9 For This Useful Post:
joshbaker96dually (10-24-2010), koga07 (12-02-2010), WUTNOIZE (01-26-2010)
Old 01-26-2010, 08:27 PM   #6 (permalink)
95dually3500's Avatar
Drill about an inch back from the flange or the side by the firewall, 4,5,6 cylanders are hotter than 1,2,3
96 2500 Reg Cab 4x4 - AFE Stage 2 Intake, Pusher intake 4k GSK,ground plate, pump tuned,fass 150 , Autometer-Gauges,Built auto w/Goerand Tripple,Disc
ED BIllet 66/68/.8 & 5x14's SDX Comp DV's 17.5* timing,
95dually3500 is offline   Reply With Quote
The Following User Says Thank You to 95dually3500 For This Useful Post:
Old 01-26-2010, 09:09 PM   #7 (permalink)
WUTNOIZE's Avatar
thanks guys for all ur help and reassurance
