1996 Dodge Thermostat - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 01-25-2010, 10:09 PM Thread Starter
Leroy Cook's Avatar
I have installed four (4) new thermostats in my Diesel. None of them work right. I now have less heat that with the original.
The original doesnot look like the replacements. Any ideas?
Leroy Cook is offline
post #2 of 17 (permalink) Old 01-25-2010, 10:24 PM
95dually3500's Avatar
Get one from cummins or the stealership and make sure the hole is up top. Are you sure that you dont have an air bubble in the system, if you do yo wont get heat. Make sure when filling up the coolant that the front of the truck is a little higher than the back, exspecially the fill side. It sounds dumb but it helps get the air out when filling
96 2500 Reg Cab 4x4 - AFE Stage 2 Intake, Pusher intake 4k GSK,ground plate, pump tuned,fass 150 , Autometer-Gauges,Built auto w/Goerand Tripple,Disc
ED BIllet 66/68/.8 & 5x14's SDX Comp DV's 17.5* timing,
95dually3500 is offline
post #3 of 17 (permalink) Old 01-25-2010, 10:39 PM
Sebastian's Avatar
What make you think they are not working? Overheating? no heat from the vents?
96 4x4 bhaf, gauges, #10 plate,4" exh, 4.10's, 35" tires, Billet converter & input 34 psi hx35, ported exh manifold, pusher intake manifold. SDX II's & 4k gsk
Sebastian is offline
post #4 of 17 (permalink) Old 01-25-2010, 11:04 PM
nostroker's Avatar
Don't mean to butt in, but I have the same problem. NO HEAT! The temp runs normal, but good cool air coming out of the vents.
Just a farm truck, with some extras!
2007.5 Dodge Ram 3500 C/C 6.7L, auto, 9'.4" CM HAULER BED, front replacement, H&S XRT with deletes and S&B INTAKE!
nostroker is offline
post #5 of 17 (permalink) Old 01-25-2010, 11:17 PM
ykdave's Avatar
If the temp is up to normal and your lacking heat in the cab you likely have a blockage in the heater core (either on the antifreeze side or the air side) not allowing proper heat transfer.
If the temp gauge stays low you likely have a thermostat issue
ykdave is offline
post #6 of 17 (permalink) Old 01-25-2010, 11:33 PM
nostroker's Avatar
What is actually normal on these trucks? This one runs just under half way.
"(either on the antifreeze side or the air side)"??????????
post #7 of 17 (permalink) Old 01-26-2010, 04:05 AM
Normal operating temp is 180*. Your needle should read a fraction below the 190* mark on temp gauge.
What YKDave is saying is that you either have a blocked heater core preventing antifreeze from flowing through it or you have some type of air issue inside of cab not allowing air to flow through it. It could be either one. If it is a waterflow issue, I have read of some using CLR to flush core only. Most times when water won't flow I just replace because age will catch up with them eventually.
RPegram is offline
The Following User Says Thank You to RPegram For This Useful Post:
nostroker (01-26-2010)
post #8 of 17 (permalink) Old 01-26-2010, 11:28 AM
nostroker's Avatar
Mine must be reading too low, I watched it again today while on a 50 miles hwy drive and it is actually just over a the 1/4 mark, well below the 190* 1/2 way point, so my thinking is t-stat problem and not running hot enough.
Make any sence?
post #9 of 17 (permalink) Old 01-26-2010, 11:32 AM
glfredrick's Avatar
Make any sence?
Try a piece of cardboard over the radiator.
Make SURE you cut a hole about the size of a 5 gallon bucket in the center of the cardboard so the fan can draw some air.
If the heat comes up good after that, you are just running too cold overall in the system, which can happen in really cold areas. I've covered most of my diesel truck radiators as a normal winter condition over all the years I've drove diesel truck equipment in Wisconsin. For big trucks, we get a winter front that snaps on over the grill shell with flaps that open to allow more or less air. Pickups could do that also, but cardboard is cheaper.
Just watch your temps once you do it.
1995 D2500 4x4: #10 fuel plate, BHAF, turbo orfice, AFC forward, 3000 GSK, pyro & boost ga. NEXT: trans ga & filt, 4" exhaust, billet TQ, valve body.
UCORA.org -- United Christian Off-Road Alliance.
glfredrick is offline
post #10 of 17 (permalink) Old 01-26-2010, 11:48 AM
The main problem with low coolant temps on these trucks is they aren't being used for what they were designed for, work.
Put a load behind them and you'll glad the cooling system is massive.
Cummins got tired of people complaining about low temps so in '98 and turned the gauge into an idiot gauge that doesn't read the true temperature.
No more complaints.
But if you aren't getting enough heat in the cab try running the control set on recirculate.
If that doesn't work your heater core may be plugged.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #11 of 17 (permalink) Old 01-27-2010, 12:45 PM
Has anyone tried putting a 12v or 24v electric pump in the heater supply line? This would be a bit of a job with the steel lines. I tried running on recirculate and the windows fogged up. I have been running with just the coolant radiator covered with a 4'' diameter hole in it and little or no noticeable heater improvement. I have checked all of the air valves. This is a design defect/problem that apparently corrected on later models. Driving this thing reminds me of the 1935 Ford my grandpa had with the only heat coming off the exhaust manifold, except the Ford would blow hot air when it got up to 50 MPH. I have been reluctant to cover the transmission and A/C radiators but will have to try that instead of just covering the coolant radiator and I should get by with it it when I am not pulling a load. The window sticker on this truck was $37,685 and for this I get to freeze my butt off in the winter. Has anyone had any experience with the 12 volt electric heaters that plug in to the accessory outlet? Thanks.
tush is offline
post #12 of 17 (permalink) Old 01-27-2010, 12:48 PM
I run mine in recirc almost all the time in the winter.
No fogging problem if you just crack open a window.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
