Okay, I know somebody has posted this before, but I can't find it. I'm trying to find the thread about homemade timing tools... Something about using a drain plug from the oil pan or something... Can somebody steer me in the right direction? Thanks!!!
1998 2500 Ext Cab 12 valve Auto 4x4, 15.75*, Pensacola Stage 1s, 4" Turbo Back Exhaust, K&N Replacement Filter, Di Pricol Gauges, #10 Plate 1/2 back, Goerends Tranny w/ Triple Disk TC & new VB, w/ VBA
#2 (permalink) |
Coaltrain Diesel Performance
Is this the one you are looking for. Anyone rent timing tools?
Modified 97 3500 CoalTrain Diesel Performance Richard 734-673-4867 Full line of diesel repair and performance items. Custom injectors, turbos, injection pumps, gauges and more! Wicked Werks Distributer CoalTraindieselperformance.com |
#3 (permalink) |
I know this is an old thread, but... Does the drain plug screw in where the adaptor normally would in the DV threads??? Also, why would you thread the hole in the center of the drain plug? It sounds like you could just hold it still with the set screw... Finally, will this work without the special "tip" for the dial indicator if I get the one from Harbor Freight??? Thanks...
#6 (permalink) |
The center hole where the gauge slides thru does not get tapped or threaded. The set screw (the screw sticking out the side does get tapped). You also might need to use a washer or spacer (just like a gasket on your drain plug) to take up a little space. Yes, the normal $10.00 HF gauge/indicator works without any special adapters. The drain plug just screws in using the normal DV threads. The drain plug gets threaded in, then the gauge, tighten set screw enough to hold gauge but not crush the shaft. Follow this link: Dodge Diesel, Diesel Truck Resource Galleries - kd460 Gallery - Powered by PhotoPost YD Last edited by Yankee Dog : 06-01-2007 at 03:31 AM. Reason: add info |
#7 (permalink) |
delivery valve threads
Is the size of the delivery valve threads an unusual size, or could I easily find a bolt to modify for the indicator holder.
1998 2500 4x4 Quad cab 12v 215HP pump, nv4500 242,000K miles all stock, KDP killed. I'm gonna try to get 750,000+K miles by taking great care of it!
#8 (permalink) |
Let me answer it this way: The drain plug size for our trucks is 22mm x 1.5 I don't know if you can find a bolt locally in that size or not. Then you still have to drill and tap it. The drain plug is like 8 bucks plus shipping, and seems to do a good job. Can't beat the price. Here is a link to the place I picked up mine. Metric Oil Drain Plugs What I did was buy a magnetic one, and used my old one as the holder. YD |
#9 (permalink) |
thanks for the info, great link. I would not be surprised to have several of these laying around in the shop I work at, unless (like U said) it is not a typically used size??
