power steering and brake problems - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 12-21-2009, 12:54 PM Thread Starter
tattooed diesel's Avatar
My power steering works ok as long as I have my foot into the throttle. When I slow down I lose it and so when I pull into the parking lot of a store I have to gun it and pull into a slot real fast which scares my wife ha ha. I also usually have enough brake to stop but they are not right. Sometimes there is barely enough to stop me. If I push on the brakes I cant have power steering also. Both of my brake lights stay on all the time. Is this all caused by the power steering pump or is there another issue.
tattooed diesel is offline
post #2 of 20 (permalink) Old 12-21-2009, 01:11 PM
Rescue Tower
Shainer's Avatar
Hydroboost. Make sure you have enough powersteering fluid in there first. If that checks out you are looking at rebuilding it.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #3 of 20 (permalink) Old 12-21-2009, 06:22 PM
What year truck? '94-'96 had vacuum assist power brakes and '97 switched to hydraboost which gets boost from power steering pump.
RPegram is offline
post #4 of 20 (permalink) Old 12-21-2009, 09:27 PM
Maybe your idle is too low.
Should 750-800 rpm with auto in D or manual in N with A/C on.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #5 of 20 (permalink) Old 12-23-2009, 01:56 AM
i have the same problem mines a 96' auto. I know im leakin power steering fluid like no other (and have ALOT of free play in my steering) but even when i fill the resivor up its still hard to turn at low speeds.
countryboi2508 is offline
post #6 of 20 (permalink) Old 03-27-2010, 11:28 PM
98may7's Avatar
same problem in my 99. replaced hydro-booster,master cylinder. abs sensors. bleed the brakes till the store ran out of brake fluild... same thing. So today i was going to change the powersteering pump thinking it was putting out weak pressure. but i read so much on flushing out your system so i flushed my power steering reservoir and blew my lines clean with air. My brake pedal now returns a lot better.(brake light still on for a few seconds after off brake no long 5 mins) I can hold my foot on the brake and steer back and forth(a first). and i don't have to use both feet to stop. but it still isn't to my liking. So tomorrow im going to flush it out with a gallon of ATF and see what happens it sounds like we have the same problem to a "T" hope this help you out.
P.s can anyone tell me if there is a filter anywhere inline or in pump thanks
1998 24v cummins 4x4 automatic silencer ring MIA
95/95 fass fuel system shoulda went bigger Farmboy diesel 5inch single exhaust straight pipe with 6inch tip, edge juice with attitude
When you have the right tools Its as easy as smokin' a cigarette
98may7 is offline
post #7 of 20 (permalink) Old 03-27-2010, 11:37 PM
ykdave's Avatar
their is a pump in the pressure fitting on the back of the pump, more of a screen actually, but they can plug up
ykdave is offline
post #8 of 20 (permalink) Old 03-28-2010, 12:13 AM
DonO`Brien's Avatar
power steering
Fixing rams .com has o kit with instructions on how to rebuild vacum pump.I did both pumps for less then $200.00.Use reman power steering pump from carquest.
Don O
DonO`Brien is offline
post #9 of 20 (permalink) Old 03-30-2010, 03:58 AM
Smalleydrlgcwby97's Avatar
Question
i have no power steering now and brakes i have to literally push pedal down hard to get it stopped, mines got the hydroboost, which has been leaking for over a year and half, tonite i think it finally gave, power steering is full, vacuum pump to the front cover is leaking oil alil, front cover was replaced. any help on this matter.... New Hydroboost or what????????????????
1997 Dodge 3500 ext cab flatbed, fuel plate grind on, valair 13" clutch, 5spd rebuilt, custom stacks with custom 4in black bullhaulers, lots of LED Lites, newer towing mirrors, rolling the coal
Smalleydrlgcwby97 is offline
post #10 of 20 (permalink) Old 03-30-2010, 06:03 AM
Until you get your powersteering fixed, your not going to have brakes. The fluid goes to steering gear before going to brake booster, so with no power to gear, your not going to have brakes either. If your hydraboost is leaking, then it is definitely bad. Replacing the hydraboost probably won't fix the powersteering or give you power brakes back. You'll need to address that issue with power steering pump or gear or both. Sounds like your going to have to break down and spend a chunk of money on maintenance.
RPegram is offline
post #11 of 20 (permalink) Old 03-31-2010, 05:03 PM
98may7's Avatar
i pulled the pressure line off the power steering and took out the 1" nut that holds the valve in.. Looked thought the small filter/screen and it was blocked just about solid...so i took it all apart (spring and ball out) sprayed it clean w/ carb cleaner and reinstalled it helped with the brake pedal sticking to the floor but pedal still returns slow most of the time and have to pull it back up with my foot so the brake light goes out.. is this because there might be air in the lines yet??
98may7 is offline
post #12 of 20 (permalink) Old 10-21-2010, 09:54 PM
joshbaker96dually's Avatar
what can i look for too see if i have hydoboost?
thanks
josh
1996 2WD Dually, lots of parts. Some of them better then stock. B.O.T.T.S.R.
2006 f250. Egr delete, s&b intake
joshbaker96dually is offline
The Following User Says Thank You to joshbaker96dually For This Useful Post:
woodscapes (04-11-2013)
