- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
1995 3500 auto tranny going in and out of lockup, why?
I have a Dodge 3500 diesel truck with an automatic transmission. When I get up to highway speeds, sometimes it will shift in and out of lockup on a flat surface at a constant speed. It will lockup for a couple of seconds, then unlock for a second and then lockup again and the cycle will repeat until I either increase or decease the throttle.
What would cause this? I have been having a 'sticky throttle' sometimes and the parts stores say it does not have a throttle cable. Could the throttle position be the factor in the transmission getting confused on the throttle position and shifting in and out of lockup?
'95 Ram 3500 Dual, Auto, exhaust brake, gauges - Audio system (Pioneer Premier, Fosgate digital, 10" MB Quart sub) - Veggie Oil Powered |
#2 (permalink) |
That is a classic symptom of a bad throttle position sensor. Are you using cruise control?
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit. |
#3 (permalink) |
Hmm, it does appear to be worse when the cruise is set. And, it only seems to happen when I have the throttle in a static position.
I suspected that was the cause but this is my first diesel and wasn't completely sure how the throttle worked yet. It almost feels like a worn throttle cable even though it does not have one. Thank you very much for your help.
#4 (permalink) |
What happens is that when the TC clutch unlocks RPM goes up a little bit so the throttle moves to reduce RPM. Then when it locks up again the opposite happens. If you have a bad place in the TPS then it will do that.
#5 (permalink) |
Yup, that sounds exactly like what is going on.
Again, thanks for your help.
#6 (permalink) |
AlGores worst nightmare
![]() Join Date: Dec 2006
You DO have a throttle cable. There is even a TSB on them. Recall #970 - throttle cable
But your problem sounds more like the TPS.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering. Motor; BHAF, #100 fuel plate, Shimmed gov springs, Loose starwheel. 306hp/743tq Exhaust; Schwitzer S300G, 4" downpipe, 5" turnout stacks. Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
#7 (permalink) |
OK, I got it figured out now after taking a look at how it works under there. Looks like I can get the TPS for about $225 and will slap it on there myself.
I will hit up the local dealership for the recall while I am at it. Thanks for all of the help.
#8 (permalink) |
Super Moderator
![]() Join Date: Nov 2005
$150 for a TPS from Napa but first try this TPS testing and adjustment
Also read this 47RH Tranny Troubleshooting
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Stock for one day |
| The Following User Says Thank You to illflem For This Useful Post: | sdiesel (12-20-2009) |
#9 (permalink) |
are your mpg's suffering?
2nd gen 12v; 4x4; 3.53 rear; afe stage 2 cold air intake; 4 inch exhaust; recent rebuilt auto trans w/ low stall tq converter; 95,000 miles |
