- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
TPS adjustment??
OK i have seen a couple of post that said you could adjust the tps with a bolt up under where its mounted. If this is the case anyone have a picture because I dont find it on my truck. It is a 97 12v.
#3 (permalink) |
TPS = Throttle Position Sensor. Here's the link; TPS testing and adjustment if it doesn't work then go to forums page and scroll down to tech articles 2nd Gen 94-98. There is a lot of great information there.
95 CTD 2500 STD Cab 4X4, KDP Tabbed, Boost/Pyro, AFE Stage II, 4" MBRP Exhaust, ATS Exhaust Manifold, BD T/C and Trans w/ Torq Loc, DDP STAGE II INJECTORS, #10 PLATE, 62/65/12, CFM+ Intake, HID Head lights, ROL BAK Cover, Carli Starter Kit and Track Bar. |
#4 (permalink) |
My tps isnt slotted. It is a fixed mount. I am going to get a new tps from a parts house, im sure mine is just out of range/worn out. I alreadt tried drilling them out and rotating but could get close to spec. It started at .352 volts and the closest i could get was around .756 volts.
#5 (permalink) |
Read this: TPS myth buster - TDR Roundtable
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit. |
#6 (permalink) |
Super Moderator
![]() Join Date: Nov 2005
Way out of scale but you should be able to figure it out.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Stock for one day |
#7 (permalink) |
I will be doing a write up on adjusting a tps soon with pictures. Dont slot you tps mounting holes. This is not the proper way. You have to adjust the rod positioned below it to ramp up you tps voltage.
#8 (permalink) |
Super Moderator
Messing with the rod adjustment to adjust the TPS is totally incorrect.
Changing the rod adjustment different than the specs below will shorten your rpm range. The enlarging the the mounting hole method is recommended by the most highly respected diesel tranny builders.
#9 (permalink) |
It works better to install a potentiometer (pot) in the ground wire to the TPS than mutilating the TPS. If you use a pot you can adjust the OD shift points to some extent. Another way is to eliminate the TPS from the circuit by replacing it with a pot in the cab. If you do that you have control over OD and lockup shift points, but kick down does not work. The TPS is just a poorly designed pot that is operated by the throttle cable.
