how much power - Page 2 - Dodge Cummins Diesel Forum
post #13 of 20 (permalink) Old 11-27-2009, 12:57 PM
you should do some transmission work too, i blew my auto up with a fuel plate, 40psi boost and some other mods,
snaped the input shaft and gears right off too
98 3500 12v,Banks kit twin ram manifold, injectors,etc
96 12v heavily modded
03 24v slt crew cab 4x4,edge /smarty/ mbrp exhaust
dubbin20 is offline
post #14 of 20 (permalink) Old 11-27-2009, 01:43 PM Thread Starter
XECCLLC's Avatar
New Mod List
Straight Pipe, K&n Filter, Hard Pipe Intake Pipe, Banks 62407 Fuel Plate Full Forward( Which I Think Is A #5 From Banks Power) , Afc Full Forward, Isspro Egt And Boost Guages, Star Wheel Cranked A Few
95 2500~AUTO w/ HD TC~K&N FILTER~#100 FUEL PLATE F.F.~AFC F.F. W/ DIAPHRAM & FOOT MODS~OFV MOD~ISSPRO EGT, 60 PSI BOOST, 30 PSI FP GAUGE~3KGSK~4" DOWNPIPE~215 INJECTORS~5" CAT STACKS~T/C LOCKUP SWITCH~TRACTION BARS~ LEVELING KIT~AIR BAGGED REAR
XECCLLC is offline
post #15 of 20 (permalink) Old 12-07-2009, 12:08 PM
notomas's Avatar
Don't for get your tranny temp gauge, if your spending the money for building the tranny, spend a little more to keep it in a safe operating temp. You will be surprised what conditions actually can overheat the tranny.
A torque converter lockup is a real nice add-on also. If you do a search for tc lockup, there are a few write-ups on how to do it. As a added bonus you can control when you are locked up and use it to help keep temp down.
A boost elbow will help you dial in more boost for more power.
There are also write ups on how to make your own BHAF. Big Honking Air Filter that will flow more than the stock and filter better. I use a KnN on my racer, but I pulled it off of the work truck and built my own after seeing dust in the intake tube. Im off road alot on the oilfields dust roads.
97 2500 4x4, excab , K&N intake, 4" exhaust, egt,boost,tranny temp on the pillar, 5 star viskus torque converter, converter lock up, stage lll rebuild, #100 plate, 3gsk, boost 30psi, starwheel forward and Smoke screw adjusted for power
notomas is offline
post #16 of 20 (permalink) Old 03-02-2010, 12:22 PM Thread Starter
XECCLLC's Avatar
ok so i been building a piece at a time,
here is what i got now,
95 2500~EXT CAB~L.BED~AUTO~
K&N FILTER~
BANKS #6 FUEL PLATE FULL FORWARD~
AFC FULL FORWARD~
32-35 PSI BOOST~
STAR WHEEL CRANKED ENOUGH TO BLOW SMOKE AT HARD THROTTLE AND WITH A LOAD~
3KGSK~
TRANS REBUILT W/ UPGRADED T/C~
5" MITRE CUT STACKS~
T/C LOCKUP SWITCH
how much power, the #6 plate calls for 230 hp 600 tq so im guessing about 280 hp and 650 675 tq?
sound right?
XECCLLC is offline
post #17 of 20 (permalink) Old 03-02-2010, 12:23 PM Thread Starter
XECCLLC's Avatar
Originally Posted by illflem View Post
Your 160 pump can be modified for just as much power as modified 215 pump for half the price of a new 215.
how do you mod the 160 pump, i keep hearing from a couple guys to do that
XECCLLC is offline
post #18 of 20 (permalink) Old 03-02-2010, 02:24 PM
Avatarless
get full rack travel, your 160 has 131 dv's you can go ahead andd put 181's in it and still be egt safe.
2015 Ram 2500
2001 Ram 3500
Gone: 1995 12 Valve
,2013 Ram 1500 Crew Cab Express
honestcharlie56 is offline
post #19 of 20 (permalink) Old 03-02-2010, 04:59 PM Thread Starter
XECCLLC's Avatar
how hot is too hot on the egt
XECCLLC is offline
post #20 of 20 (permalink) Old 03-02-2010, 05:36 PM
Avatarless
dont go over 1300 for extended periods, but i have seen plenty of people runnin down the track at 1800, i dont recommend that though
2015 Ram 2500
2001 Ram 3500
Gone: 1995 12 Valve
