govener springs help asap thanks - Dodge Cummins Diesel Forum
Old 11-19-2009, 01:53 PM   #1 (permalink)
having a guy do some work on my truck we talked about the govener springs because i may do some pump work valves and a plate
he wants to charge me 200 for springs and install i looked up springs and there like 15$ what is he charging so much for labor?? or is it a 10 min job
was thinking 3200 or 3500 springs
trucks a 5 speed so i think it has higher rev point around 3000 now has a hx40 with 4" pipe
thanks
guys
chubs is offline   Reply With Quote
Old 11-19-2009, 02:02 PM   #2 (permalink)
khaoskustoms's Avatar
You are most likely looking at the wrong gov spring. Here's a link to PDR's 3000rpm gov spring.
PDR Diesel Performance: 3000 RPM Governor Spring Kit
Time wise, it can take from 1-2 hours.
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 14.9 @ 88mph 1/4 mile, 285hp @ 2700rpm and 590ft/lbs @2200rpm
khaoskustoms is offline   Reply With Quote
Old 11-19-2009, 02:57 PM   #3 (permalink)
talked with him again he said 150 for springs and 200$ labor to them and the plate and dilvery valves
what do u guys think???
says a number 8 plate is what i want
Old 11-19-2009, 02:58 PM   #4 (permalink)
o yea
told me the plate is 230$ #8
and valves are 260$ p pump one not profesional
seem right
Old 11-19-2009, 03:03 PM   #5 (permalink)
Well, you can get the 3gsk for $96 bucks here Governor Spring Kit - 3K RPM City Diesel - Diesel Performance
Grind your plate to a # 10 for free, install the gsk yourself. Unless you're seriously uncomfortable doing it. You'll save lots of bucks, and its not hard at all, plenty of people here to help. You're gonna get ALOT more bang for the buck buying and install your own parts, for what its worth.
1994 3500 CTD, 5spd swap complete, 100 plate, 3gsk, 181 dv's, Banks Twin ram, 4" straight to 6" tip
Box5 is offline   Reply With Quote
Old 11-19-2009, 03:25 PM   #6 (permalink)
how do i grind the plate to a #10
and how hard is it to install the valves?
Old 11-19-2009, 03:29 PM   #7 (permalink)
Be aware, it is not always easy. Each truck is different, and the default adjustment they recommend is for reference only. If you do this, make sure you make take accurate measurements of the current spring-retainers to stud height, before starting; hence, settign the new springs to the previous recorded setting. If you don't, you will be starting from scratch when putting the new ones in, with no refernce.
Not a fun situation either! This happened to me. Previous owner put new 4K GSK in, but did not adjust them. It took me 4 tries, about 6 hrs, to finally get them tuned correctly.
98 Ram 3500 Dually 4x4 Quadcab. HP215 IP, Bosch injectors, AFE Filter, 60lb springs, 4K GSK, BD Super B Special, Silverline 4" exhaust, gauges, 47re stage 5 billit in/out shafts,dunrite VB, MAG-HYTEC 727DD pan, ATS 5-star TC, Borgeson gear box.
FlaCracker is offline   Reply With Quote
Old 11-19-2009, 06:57 PM   #8 (permalink)
Farmram's Avatar
Just get get a plate on eBay and put it in yourself. Plates are like 30 bucks and doing it yourself saves you a ton of money plus you can say it really is your truck and not someting someone else built.
98 Dodge... slow and unreliable
95 CJ-7... Cummins power and 37's
Farmram is offline   Reply With Quote
Old 11-19-2009, 07:03 PM   #9 (permalink)
yea i bought a number 8 plate on ebay 30$ to my door
10 seems to much 4 me and what i do
found 4000 govener springs for 16$ new the doubel up your factory spring creating 4000 rpm springs
now just delivery valves
Old 11-19-2009, 08:04 PM   #10 (permalink)
Isn't a 8 more fuel than a 10?
With a 4gsk be careful you don't rev above about 3400, thats when you can float the valves. Installing them is pretty easy, theres some good tutorials on here and dtr for it. Just count each 1/4 turn of the hold down screw, and install it the same amount and your idle will be pretty darn close again.
Old 11-19-2009, 09:07 PM   #11 (permalink)
colin91's Avatar
$16 for governor springs? doesn't sound like a good quality spring kit, who makes them. I paid $115 for mine
delivery valves can be put in pretty easily, the DV socket helps. GSk can be done in 1-2 hours easily. I'd just do it yourself rather than pay someone else. Thats always been my thinking on it
1996 2500 ECLB, NV4500, 4X4, HTT 62/71/14, SDX 5x14s, #0 plate, 20*, 4K GSK, ARP studs, Snow water/meth, SouthBend, 5" EXH, AFC fiddled with, Icebox, ATS 3pc, PacBrake PRXB, Isspro gauges, As much Thuren as i can afford, KDP victim, more to come
colin91 is offline   Reply With Quote
Old 11-19-2009, 10:07 PM   #12 (permalink)
heres a link to the kit it uses your stock ones also just doubels them up
Pure Cummins Diesel Performance - GSK Inner Spring Kit, Converts a 3k GSK to a 4k GSK 94-98 12 Val from PDR Diesel #pdr2010740_x2
i just found that out tonight about the valve springs what pound springs will i need to replace them with and i dont know if that 15 kit is any good talked to guy on the phone said they work great???
