Old 11-18-2009, 10:36 PM   #1 (permalink)
Got owned tonight
So I slid my #6 plate halfway forward and cranked the starwheel all the way. With my mods below I raced a buddy of mine tonight in a bone stock 94 ctd auto dually 2wd. It only has a small air filter and cut off exhaust. He beat me from a red light. Im clueless of why. Im guessin its because of my boost pressure (12-14). Any ideas? Possibly timing?
1994 CTD 4x4: AFE Intake, 5 Inch Turbo Back to 5 inch Aussie's, Starwheel FF, AFC FF, #6 Plate FF, Auto with a hd tc and lockup, Gauges, 3 GSK, 370 Auto Injectors
mightywhitey5269 is offline   Reply With Quote
Old 11-19-2009, 02:05 AM   #2 (permalink)
B.B.'s Avatar
12 to 14 is really low, Stock I had a little over 20 to 25. I would defiantly look for a boost leak.
97 3500 DRW
03 3500 DRW
B.B. is offline   Reply With Quote
Old 11-19-2009, 08:14 AM   #3 (permalink)
yea exactly. Is there a sticky on it? I checked the boots for wear and tear. Where else can you get boost leak at? thanks in advance- Andrew
Old 11-19-2009, 10:02 AM   #4 (permalink)
get a spray bottle of soapy water, and spray it on all the boost hoses and look for bubbles. Also, he could just have a better auto than you, since the auto is what either plants or sucks up all the power.
1994 3500 CTD, 5spd swap complete, 100 plate, 3gsk, 181 dv's, Banks Twin ram, 4" straight to 6" tip
Box5 is offline   Reply With Quote
Old 11-19-2009, 11:37 AM   #5 (permalink)
get a 4" PVC cap and a 4" hump hose, put a schrader valve in the cap and pressurize the front of the turbo... this will pressurize the entire boost tract and makes it easy to find leaks
'06 Mega Cab 2500 4x4 auto. tranny by HotRodDiesels, Smarty, Fleece Performance stand-alone VNT setup, etc. "it makes cool noises"
drunk on diesel is offline   Reply With Quote
Old 11-19-2009, 03:28 PM   #6 (permalink)
Thanks for the replys. I dont think its the auto, because he has 180xxx on his and completely original. I got a new tc and it shifts firm in all gears. Im goin to try and do those test on it this weekend
Old 11-19-2009, 04:58 PM   #7 (permalink)
cummins_nut09's Avatar
try plugging your waste gate under the turbo. I am getting 42psi.
96 12V Cummins 5 spd. SB Clutch, 4k GSK, no fuel plate, Scheid 370 injectors, Laser cut DVs, 15.5 deg. timing, K&N intake, 4" exhaust w/ 8" tip, boost, pyro and fuel press. gauges, 160gph PPE lift pump, 33" BFG MT's, 17" Moto Metals
cummins_nut09 is offline   Reply With Quote
Old 11-19-2009, 05:43 PM   #8 (permalink)
Bluedually4x4's Avatar
Generally boost leaks are around the boots, but you could have a hole in the intercooler.
1998 3500 4x4 5 speed reg cab dually 12valve
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, 75 hp injectors
Bluedually4x4 is offline   Reply With Quote
Old 11-19-2009, 06:13 PM   #9 (permalink)
tight converter + 35" tires will hurt too
Old 11-19-2009, 09:12 PM   #10 (permalink)
colin91's Avatar
lower gears than him plus the extra weight of a transfer case and front axle?
1996 2500 ECLB, NV4500, 4x4, 4" redneck exhaust, PacBrake, ATS 3pc, #0 plate, 16*, 4K GSK, wastegate plugged, SouthBend, welded 5th gear, Isspro gauges, leveled, Thuren track bar, AFC tweaked, BHAF, silencer ring?, wounded by the KDP, 15%/5% tint
colin91 is offline   Reply With Quote
