Old 11-18-2009, 12:17 PM   #1 (permalink)
khunter_2007's Avatar
5.9 swap
what all do you have to do to swap a cummins into a gasser 1500
what all wires will i need and are the axels dana 60 or will ui have to swap them too
94 cummins , hx40 , 370 marine injectors , 3k gov springs , laser cut dvs , cam , lockup controler , tci stage 5 tc , suncoast valve body , 150 shot , 5 psi of propane , #10 plate slid , afc slid , extreme duty clutch kit , 6 in . stacks
khunter_2007 is offline   Reply With Quote
Old 11-18-2009, 01:10 PM   #2 (permalink)
12valveterror's Avatar
thats probably not a feasable swap, more time then money than youd really wanna spend, you gotta factor in all the heavy duty suspension components as well with a 1500 cause thatll hardly hold the weight of cummins engine. from swapping the axles, shocks, front suspension, wiring youd be better just buying a 2500 imho
97' 2500 12V, 4x4, Auto, Dunrite Triple Disc T/C & V/B, 4k-GSK, Bilstein 5100 Shocks, DSS Stablizer, DiPricol Optix Gauges, #0 Fuel Plate, 14cm Non-Wastegated Housing, Amsoil 4510, T/C Lockup Switch, 15* Timing, 4" Turbo Back to 5" Mitres
12valveterror is offline   Reply With Quote
Old 11-18-2009, 05:53 PM   #3 (permalink)
can be done but you will be switching all the 1500 parts to 2500 parts to handle the extra weight. I my opinon it is not worth it.
why do you want to do it?
94 Dodge 1500 black regular cab 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg (Friends) 95 Dodge 2500 4x4 boost elbow (35psi) #6 fuel plate http://www.cumminsforum.com/forum/cu...ics-truck.html
JakeDiesel is offline   Reply With Quote
Old 11-18-2009, 09:04 PM   #4 (permalink)
Bluedually4x4's Avatar
Pretty much everything in front of the windshield, minus the hood, fenders and the bumper.
1998 3500 4x4 5 speed reg cab dually 12valve
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, 75 hp injectors
Bluedually4x4 is offline   Reply With Quote
Old 11-20-2009, 12:52 PM   #5 (permalink)
what about the 2500 with the v10 are they the same
Old 11-20-2009, 05:08 PM   #6 (permalink)
Yeah they are the same. if you get a v10 with the 5spd they are the same as the 5.9 too. autos are different
Old 11-20-2009, 11:01 PM   #7 (permalink)
Frame? Once you swap all those parts over the frame is still going to be light duty. Another vote for 2500
FleetwoodCummins is offline   Reply With Quote
Old 11-21-2009, 02:23 PM   #8 (permalink)
still a 2500 frame. its the 1500 frames that cant handle the extra weight and the twist that comes with the cummins
Old 11-21-2009, 06:17 PM   #9 (permalink)
How about you take a reg. cab long bed and make it a reg cab short bet get a new bed and shorten the frame might be just as easy.
96 ext cab long bed Silencer Ring removed, No fuel plate, 4in turbo back, K&N Intake,...more to come
twarek04 is offline   Reply With Quote
