Turbo question - Dodge Cummins Diesel Forum
Old 11-10-2009, 10:53 AM   #1 (permalink)
mjr45's Avatar
Turbo question
96 2500 4X4 with gauges, 4K gsk, BHAF, 4" turbo back, boost elbow, 10 0 plate and prime lock. When I first put the mods on, boost would hit 30psi, now at 22-24psi the pop off goes and drops all the power, egt runs 1150 when towing in 5th gear. Causes real probs when towing. Any clues as to the problem?
mjr45 is offline   Reply With Quote
Old 11-10-2009, 12:04 PM   #2 (permalink)
BigT18's Avatar
I'm having a similiar problem... but i hear a hiss from the drivers side. I tried finding a leak using compressed air into the turbo using a adapter i made but i got nowhere. Cruising around my boost dropped from like 6 psi at 65 to about 2-3 psi. It only boosts to 25ish psi. Used to do atleast 34.
1995 Cummins 12v Reg. Cab 4x4 5 speed, 250,000 miles, boost/pyro, straight piped side dump, #10 plate, pump cranked
BigT18 is offline   Reply With Quote
Old 11-10-2009, 12:13 PM   #3 (permalink)
Got P7100?
mathews8pt's Avatar
iTrader Score: 7 reviews
either a boost leak or the wastegate actuator is opening when its not suppose to. More than likely a boost leak from what you are saying. Check everything over very well and if you can build a plug for the turbo use some compressed air and soapy water to check for leaks as well.
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s468, tranny built by me, AD150, 11.60@117mph
1999 QCLB comp box and a trans by me - tow rig/DD
mathews8pt is offline   Reply With Quote
Old 11-10-2009, 01:53 PM   #4 (permalink)
calebmcclellan's Avatar
iTrader Score: -1 reviews
check the lower boot on the pass side. they will expand and rub on the sheetmetel and tear a hole
86 C/20 w/94 12v 420k miles http://www.cumminsforum.com/forum/cu...chevy-2wd.html
calebmcclellan is offline   Reply With Quote
