Old 11-07-2009, 12:51 PM   #1 (permalink)
speedntriple's Avatar
Lost my starwheel cap! Help!!!
Looks like the AFC starwheel cap vibrated off due to me not tightening it down enough... Anyone have a spare or solution other than going to Bosch?
99 24v 4x4 5sp 5" str8, SB, AFE, AD150, ATS arc flow,Drag Comp, Jammer 4s,gauges,DSS, Ranch hand front/rears,steps, 18" Rockstars, 2" level, PSC
94 12v, 2wd, AT,#0, pump mods,built trans, dragon flows gauges in.ex
speedntriple is offline   Reply With Quote
Old 11-07-2009, 12:57 PM   #2 (permalink)
estrada5.9's Avatar
Get the thread pitch and make one should be able to call up a cummins shop they may have that info. Who knows may be there only five bucks and they stock them at the store.
1997 2500 4x4 5spd 35/3b
2003 2500 4x4 6spd 62/71/14 over S472
2000 Jetta TDI 5spd
estrada5.9 is offline   Reply With Quote
The Following User Says Thank You to estrada5.9 For This Useful Post:
speedntriple (11-07-2009)
Old 11-07-2009, 01:09 PM   #3 (permalink)
yeah too bad cummins atlantic is closed today... ima try and make one ifn I can. thanks man!
Old 11-07-2009, 01:18 PM   #4 (permalink)
Here's how someone replaced theirs a couple of weeks ago:
95 2500 Cummins auto - seems luggish and low on power
Scroll down to post #116.
RPegram is offline   Reply With Quote
The Following User Says Thank You to RPegram For This Useful Post:
Old 11-07-2009, 02:17 PM   #5 (permalink)
sweet! cut down an old o2 sensor. fits like a champ! thanks fellers!
Old 11-08-2009, 01:09 AM   #6 (permalink)
Call a bosch shop. There not to bad on pricing usually.
1998 qclb nv4500 w/ 6" miters, K&N, 4000gsk, kdp tabbed, #100, afc tweaked, silencer ring mia, gauges, leveling kit, 35's, sb 3600, nv271D swapped, 5th gear fixed, and lots of oil leaks. Coming soon: more traction, more lift, more power
da boss is offline   Reply With Quote
