Alright i have a delema...
so i was on my way back from ohio today and stoped to fuel up, when i came back out from paying i noticed some oil under my truck...so im like sh%t... i get under it and there is a crap load of oil on the ground and under my truck, so its only a 2 mile drive home frome where i was so i get home and pull it in the shop and get the light out and look and it looks like its coming from the transfer case, and i dont mean a little oil i mean alot, im suprised there is even any left in it, oh and also when i was on my way home before i noticed the oil i started to hear a weird noise coming from the shifter boot area, maybe that has something to with it i dont know im not a professional...anybody got any ideas?? thanks
1994 dodge, 4x4, nv4500, single cab long bed, autometer guages, #100 plate slid, exhaust, and cold air intake. |
#2 (permalink) |
I did not have a drop of oil under mine, but I had an issue with my automatic, the rear portion of the housing that the case bolts to, snapped off completely because the tranny shop was lazy and had not tightened up the bolts properly.
1995 2500 4x4 Auto No mods as of yet, too much time modding the fun truck. |
#4 (permalink) |
The seal between the trans and transfer case may be out allowing fluid transfer between the units. Check transmission fluid level.
2006 3500 Mega 4X4 Laramie 2001 2500 Quad 4X4 Laramie 1985 GMC K3500 4X4 Cummins 5spd Gear Vendors 35s. I Built this in 1996.HOOKED ON CUMMINS NOTHING STOCK |
#5 (permalink) |
Veggie Burner
![]() Join Date: May 2009
to illflem, are we talking motor oil, or gear oil/ATF?can you give an exact location of where it's comin from?
1997 2500 SCLB 290,XXX - 5-spd. 4x4, pump tuned with #10 plate, K&N CAI, no sil. ring, KDP tabbed, Autometer C2 Boost, Pyro, & Fuel gauges, BFG All-Terrains, HD Veggie Oil System, B100 & WVO burner! Working on the VGT Turbo conversion, soon to have Valair single disc... http://s224.photobucket.com/albums/d...20the%20Dodge/ |
#6 (permalink) |
i had the same problem theres a way to tighten up the trans pan well on myn there was and it stoped leaking
1996 CUMMINS QCLB, 4X4, 370 MARINE INJECTORS, ATS TRANS, 4IN TURBO BACK EXHAUST TO A 5IN TIP, BD TOURQUE CONVERTER, TC LOCKUP SWITCH, NO FUEL PLATE, 18IN CHROME WHEELS 35" TIRES, AND SOME PUMP TWEAKING TRICKS I NEED MORE MONEY
#7 (permalink) |
12veg i could not tell where it was coming from because there was so much all over the place it was hard to tell.....i just dont even know what to do, i looked at the trans and it was dry but the t case was coated with oil. the oil is not red its just normal black. so i dont know
#9 (permalink) |
hm well if its black and comin from the trans case man idk what to tell ya that doesnt sound good if straight oil is leaking from ur trans case id get that baby to the shop
#10 (permalink) |
Veggie Burner
what about rear main seal? I don't know much about the driveline/lower engine area of these things. The normal drop or 2 was probably from the CCV (Crankcase Vent).
#11 (permalink) |
Start checking oil levels in engine, trans and t-case. If you got a bad leak one of them should be low or getting low. Once you find it, fill it, clean it and get it fixed ASAP or face some major repair bills.
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
