At my wits end
I just replaced my tps but my truck still shifts early and shudders when it goes from 1st to 2nd. Any suggestions
1997 3/4 standard cab. Boost elbow, #10 fuel plate, Pyro, Boost, and Trans Temp, 4 inch stainless. bhaf |
#4 (permalink) |
Had the problem for a while and just recently had the TV cable replace by the dealer under a recall. Still has the same problem.
#5 (permalink) |
You can pull the TV cable out and this will delay shifts. This cable is the one that is PULLED out when you give it the throttle. The other two (one is cruise and one is throttle going to go pedal) pull in. There is a button you mash and pull the cable out. Beware button is a bear until you figure it out. Front band out of adjustment can also cause harsh shifts. When was last time bands were adjusted? When was last filter and fluid change? A clogged filter can cause erratic and harsh shifts. Other problems can cause and are related to governor (has solenoids to monitor pressure) and it's valves in valve body.
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
#6 (permalink) | |
Global climate change is natural phenomenon, exploited by the unscrupulous, for political and monetary gain. ![]()
#7 (permalink) |
Filter and fluid was changed 4 months ago, bands i have no idea nor do i know how to. Any links
#8 (permalink) |
Here's a link for band adjustment: 94+ Ram AT band adjustment
#9 (permalink) |
Also if I manualy shift the problem goes away.
#10 (permalink) |
Here's a link to some info given to me a few months ago: Dunrite Converters :: Frequently Asked Questions I didn't have the shudder, but had a quick 2-3 shift. Check your TV cable well and try unplugging PCM for a while and then plug it back it in. Make sure there is no slack in the cable and have someone watch while you depress go pedal and look at trans to make sure lever starts moving as soon as you start depressing cable. Look that cable over VERY carefully, as it can cause early erratic shifts.
