Truck still seems like its not charging up...
I just replaced batteries and alternator...both batteries tested bad, and the alternator had bad coils...not surprising with 6 year old batteries and the original alternator at 178k miles. But what could be causing the truck to not charge. When I first start up the truck runs for about 45 seconds then ill watch the voltometer jump to 14 then it falls back off and seems to fluctuate between 12 the whole time im driving. And at each start up its just sluggish. Any suggestions? I should probably make another thread but can anyone inform a newbie on how to adjust my wastegate on this truck or can it be done?
1996 Ram 2500 5sp. fuel plate, intake, 4in. straight out, golden fuels 160gal. nomad system, 45 hp injectors. |
#2 (permalink) |
Does your tach work? The PCM registers whether to charge or not from the tach.
1998 12 valve Quadcab with flatbed 5 speed #10 plate push full forward and starwheel cranked. |
#3 (permalink) |
yea, ive continually adjusted my idle but still sometimes in colder starts it doesnt want to sit at the 800 rpms i set the idle at while its running....thats another continuing problem. The truck really wont start without me hitting the throttle and then drops below about 700 then finally bounces up to 800 after a few minutes. Do you know what reading engages the alternator to start cycling?
#4 (permalink) |
IIRC anything over 4 or 500rpm from the ESS will 'tell' the PCM that the engine is running. It is normal to see the voltmeter fluctuate after starting, its just the grid heaters cycling. they draw 195amps which is obviously more than the alternator output, thus the voltage drop.
97 Ram 2500 / 5.9ctd /NV4500/241DHD Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
#5 (permalink) |
yea i understand that, i just dont get why the batteries are still not putting down any kind of cranking power at start up...they are brand new and the biggest you can put in those pans without modding them.
#6 (permalink) |
well, that would be a whole different situation if your having trouble starting... If its slow cranking it could be a bad connection on the battery cables or the starter solenoid contacts. Also, just because its a big battery means nothing. what are the specs on it? I have a pair of 1000cca batteries in my truck that are smaller than the 600cca batteries that i took out of it!
#7 (permalink) |
well sorry the biggest batteries in cca that would fit these trays without going commercial or modifying the trays. ive checked all the connections and all the grounds on the truck, but ive heard of some kind of sensor on these trucks that sometimes gives trouble with the battery system...but i have no idea what it is so i cant check it.
#8 (permalink) |
their are temp sensors under the battery tray(s) that tell the PCM if the batteries are getting hot (overcharging)
#9 (permalink) |
bump anyone else have any ideas?
#10 (permalink) |
Might need to have the starter overhauled. If you drive the truck for a bit, then kill it, does it still have trouble starting? You might have gotten a faulty alternator. As for the wastegate, just unplug the line that comes out of the bottom of the unit, slap a bolt in the line, hose clamp it and you're good to go.
Trust me.... I'm a doctor. 94 12V NV4500 2wd - #100FF, BHAF, 3GSK, 4" FBD Straight 98 12V Quad Cab Shortbed SLT 4x4 - Auto with a "few" mods |
#11 (permalink) | |
1998.5 Dodge Ram 3500 4x4 5speed only cold air intake, 50hp injectors, 3 piece manifold for now. Came with bags that are not hooked up
#12 (permalink) | |
