Starters
Does anybody make a good aftermarket starter for our trucks?. Thank you in advance. Brian
2007 5.9 ctd, edge,afe,silverline,37s 1998 12v, single/fuel 652hp 1191 12.11@109mph/old set up 1994 12v- Project Red. Regular cab |
#2 (permalink) |
whats the matter with the one you got?? if it clicks once when you turn the key just get a contact kit for it and it should be fine
my rig 96 2wd reg cab, 373k, K&N. Replacment airfilter, homemade 4in. ![]() ![]() ![]() http://s338.photobucket.com/albums/n...n12350inhofer/ |
#3 (permalink) |
Broke some bolts off when attempted to rebuild it. Went to drill the bolts and missed the one and created a whole in the starter.
#4 (permalink) |
Go to carparts.com and find you a good used one and upgrade the contacts and brushes and you'll have yourself a great starter.
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
#5 (permalink) |
Moderator
![]() Join Date: Nov 2005
Get rebuild parts and do it yourself or buy an OEM. Both here LarryB's Dodge starting problems solved here.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Not stock |
#6 (permalink) |
Thanks alot guys.
#7 (permalink) |
Here is another source for starters. Mean Green Starters and Altenators - Mean Green is the manufacturer of Gear Reduction Starters, Altenators, Stainless Steel Receiver Hitches and Jeep TJ Dual Battery Trays.
95 Auto, billet TC and modded valve plate, BHAF, Aux lift pump, three position lockup switch, full gauges, #5 plate, no muffler and CAT is gutless. Timed at 15.5, full EGR brake package. |
#8 (permalink) |
Nice, I wasnt sure if mean green made them or not. I used to run mean green on my rockcrawler. Thanks alot.
