Old 11-04-2009, 07:15 PM   #1 (permalink)
ShortBedCrew's Avatar
47RH, are they junk?
Im getting one on Sunday so I called a trans company to see what type of internals I could buy to beef it up a little. The parts guy pretty much told me that the 47RH will NEVER hold up in my truck with the mods in my sig. I told him it has a fresh rebuild and a brand new triple disc converter and he said it didnt matter. Not what I wanted to hear! I know you guys run them, so what do I need to do to this tranny to make it last? The trans has the following:
Just rebuilt w/ new clutches and plates
BD triple lock converter
NO valvedoby mods
48RE input shaft
The truck is just a toy, does NO truck pulling, does NOT pull my camp trailer. Just a daily driver, maybe a rolling 15mph race every now and again. Help please!!
1981 chevy 1 ton crewcab,shortbed, 95' CTD,HX35/ST50 twins,#100 plate, 15* timing, boost elbow,385 hp injectors, 4" exhaust, BHAF,3K gsk,SB clutch,8" lift,205tcase,4.11s,14r/60f both w/detroits,38"toyo MTs,18x10 chrome.SHES A BEAST!
ShortBedCrew is offline   Reply With Quote
Old 11-04-2009, 08:03 PM   #2 (permalink)
Give Dave Goerand a call and he will set you up with what you need to make it hold up.
RPegram is offline   Reply With Quote
Old 11-04-2009, 09:25 PM   #3 (permalink)
Moderator
My understanding is the high hp guys racing and pulling prefer the RH over the RE.
No problem getting an RH to hold 600 hp.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 11-04-2009, 09:34 PM   #4 (permalink)
I have seen Goerand talked about as the best, I will call him tomorrow......that sounds expensive! Thanks for the replies
Old 11-04-2009, 09:39 PM   #5 (permalink)
youngcummins08's Avatar
Let's put it this way, the dmax guys will put a 47rh/re behind a dmax when they get up in the real high power levels.
my rig
96 2wd reg cab, 373k, K&N. Replacment airfilter, homemade 4in.
http://s338.photobucket.com/albums/n...n12350inhofer/
youngcummins08 is offline   Reply With Quote
Old 11-05-2009, 03:51 PM   #6 (permalink)
THATS THE KIND OF STUFF I WANTED TO HEAR!!!
